Hey all, usually when I have a problem I turn to this forum for clues. However in this case couldn't find anything. Anyway stopped at the servo, locked the car with the key fob, but going back to the car the keyfob stopped working.
After 1 hr waiting for the NRMA. It turns out you can access a hidden door key hole by removing the panel on the drivers side handle. If you look under the handle there is a hole to put your key/ a screw driver and twist to remove the panel. You will see the key hole exposed.
clever stuff.
clever stuff.
