Tyres - New tyres for Tiguan
  • Tyres - New tyres for Tiguan
    47,000 km on the clock and time to replace the tyres. Has anybody else replaced the Hankook Dynapros and what with.
    That's a very good mileage, I would be using the same unless I knew that the replacement will be a better/longer lasting tyre.
    Performance Tunes from $850
    Wrecking RS OCTAVIA 2 Link
      I agree.
      47k is quite an achievement for a tyre.
      I will be going kumho's on mine but i don't know if they will last that distance.
        On ~42k km I replaced the Pirelli P6's with Pirelli Scorpio STR's. It does what it's supposed to perfectly , and looks good on the "track&field" version...
          47k is quite good, if you have been happy with them, as others have suggested I'd be seriously considering the same. I had a series 2 liberty with Michelin MXV3's on it and got 80k out of those (mostly hwy though) and was pretty happy with them all round. Let a tyre guy convince me some yokohamas were every bit as good and cheaper and quite frankly they simply weren't as good. So my experience for all its worth. If you have been very happy with them, unless your needs/driving will change, think carefully before you try somethign else.
          Tiguan TSI Catalina blue, Manual
            Hi Toner,
            Stick with the Hankooks, unless you need better grip for offroad driving. They tend to "scrabble" a bit on the loose stuff.
            Changed mine at 42000 km due to poor wheel alignment causing premature wear on one tyre, but the rear ones would easily have gone to 45000 km. This is better than I could ever achieve on at least 3 sets of Bridgestone Dueler HTs on my Forester.
            Locally, its also the cheapest tyre available.
              Got 4 new Hankooks yesterday. $190 each. Lets see how these go.
                replaced my P6's with bridgestone dueller h/p sport at 55,000ks, now at 105,000ks and wondering what to try next - P6's are expensive here and don't know that I will be able to get the bridgestones for $150 ea. again...
                  I will be amazed if I get 47k out of the Dunlop Sport 01's I have, they have 21k on them and I think 30 k will pull them up. Might have to see how you go with the Hankooks
                  MY19 162 Highline R-Line, SVP, Pano roof, Pure White
                    Just been through a tyre swap on my Tig and I must say I wish I'd stuck to the Hankooks,
                    I had the hankooks on there for 54,000k and was advised by the service manager to get Maxxis HP600 Bravos' and they were cheaper than the hankooks; unfortately I was in a bind as I had punctured a tyre with a roofing screw in the bunnings carpark; thankfully it sealed against the tyre but seeing I was close to needing new rubber I changed the lot otherwise the hankooks could have gone to 58-60k.
                    My biggest problem with the Maxxis tyres include visible sidewall bulge, poor wet grip & higher fuel consumption. The wet grip I've only found out today as it's rained for the first time in Brisbane since I got the tyres and on the flat taking off from the lights it spins the front wheels and traction control comes in; this is worse on a grade.
                    Anyway; looking at new tyres considering
                    Hankooks K415 Optimo
                    Hankook Dynapro
                    Michelin XM2
                    Yoko C-drive2
                      63k on my original Bridgestone Duellers Replaced them with another set and I don't expect to replace them again as I plan to have a new car by then!
                      MY 21 T Cross 85TSI Life| Makena Turquoise | Driver Assist Package |
                      Mods: VCDS tweaks |
                        Hi, my Tig has 43K in it and I am going to replace the tyres this year.
                        What do you suggest? I am looking for a cheaper, but silent tyre for streets and I wont be using my car off road at all.
                        Is it the Hankook I should choose?
                        MY18 VW Tiguan Comfortline
                          The Hankook tyres won't give you more kms. We have Hankooks on Tig now and at just bit over 20k km they're probably 1/2 or more worn. I'll be replacing them with Coopers.
                            Thanks. I am not looking for more kms. I am looking for a street tyre, which is cheaper and quieter than other tyres.
                            What would be a good choice for my 18" wheels?
                              If you have time to get them delivered, I suggest you check out Tire Rack - Your performance experts for tires and wheels.
                              - Tigger73's 125TSI Build
