Help: Smelly aircon
  • Help: Smelly aircon
    Hi guys.
    Yesterday I notice that my climate control/aircon smells like a wet dog. Horrible odour. Does anyone know how I might go about sorting this out? I don't know if different vehicles aircon units need different treatment, or if it's a simple generic fix.
    My guess is that there has been a moisture buildup that's cultivated mildew or something in the ducts.
    Any suggestions would be welcome.
    Tiguan TDI, 6spd Tiptronic Auto
    Black, sunroof, comfort pack, off-road tech, tan leather, park assist & roof bars.
    Avg 7.63L/100km over 189,000kms
    This is what i am guessing.
    There was a thread on vortex about it happening, check if they had any solutions?
    Try turning the aircon off about 2 minutes before you get home to let all the cold air escape and stop condensation.
    Could also be the pollen filter.
      Thanks for that. I'll check it out.
        After a bit more searching in that thread, there was a suggestion to spray cleaner in teh vents and set the car to recirculate to get all the cleaner through the system and get rid of any mould already in the vents.
        Google vw smelly aircon and you actually see this is quite a common issue.
          Especially with diesels .....
          makes sense really .... you put dirty smelly stuff in the engine .... some of it is bound to get into the AC system eventually ....
            I had this in my Bora. It still blew cold. My mechanic sprayed something down the vents to remove excess moister, i ran the air con all the time after, turning it off before a few minutes before i turned the car off, and after a week or two and some days with the windows down it seems to have disappeared.
            Bora gone
            Vento VR6
            MKIV GSW TDI
            7P Touareg TDI
              Spray a heap of Glen 20 into the intake under the dash.
              MY20 Golf GTI TCR
              MY20.5 LR Defender P400 HSE
                Naah, Glen20 only mask the smell, didn't you see the add on TV. Get oust instead.
                Performance Tunes from $850
                Wrecking RS OCTAVIA 2 Link
                  HA HA. I've never heard of oust before, I'll have to look into it. Glen20 worked on our Corolla.
                  MY20 Golf GTI TCR
                    Hey mate,
                    We had a 2000 crApSTRA with this issue from new. After a lot of messing around with "cleaner" sprays etc at the dealer, it turned out that a seal of some sort had worn away and needed replacing deep in the aircon unit. It was done under warranty. But my experience has been that if you take it to a dealer the first few times, they will not look for this so far in, and just try the "smelly" sprays first.
                    Anyways...that car was a disaster, so another prob was just par for the course. I am sure that the VW systems are beter built that OPEL anyway.
                    2018 Ralyee Green RS wagon. Fully optioned.
                    Previous vehicles:2015 Volvo V60 Polestar (my one detour from VW/Skoda!)
                    2013 Platin grey RS wagon / 2012 White Polo GTI / 2009 Black 125 Tiguan
                      Also it could be beneficial to let the outside air in through the vents by turning air recirculation off, before turning engine off.
                        Just had my 30,000km service and they changed the air and pollen filter(s) as part of the service. I am pleased to report that the smelly aircon problem I had seems to be gone now - so must have been the filter. So if your Tig smells, there's the solution
                          Thanks for this post. I had exactly the same problem and same solution. The smell went with the pollen filter change at the 30000 service. (Despite the VW service rep explaining before the service that all cars air conditioning smells bad .. right)
                            Best part is they are cheap as chips and you can do it yourself.
                              Are they like the golfs, in the area under the glove box from memory?
                              MY11 Tiguan 147TSI (SOLD)
