erasing APR software
  • erasing APR software
    Hey this may be a silly question, or one that has already been discussed. If so, sorry in advance!
    If a car has had the APR remap done, and the dealer then plugs in the diagnostic devices at the next service, do they have the ability to "wipe" the remap, or send it back to factory settings when they upgrade any software issues?
    I wouldnt want to spend the time and money if the dealer is just going to revert it back to standard, or wipe the new software.
    I know I appear ignorant in this issue....that is because I am!
    2018 Ralyee Green RS wagon. Fully optioned.
    Previous vehicles:2015 Volvo V60 Polestar (my one detour from VW/Skoda!)
    2013 Platin grey RS wagon / 2012 White Polo GTI / 2009 Black 125 Tiguan
    Re: erasing APR software
    Apr will reflash it for u for free if that happens. I think they record ur vin no but they def don't charge u again.
      VW Dealers seem to randomly hook the cars up and do updates.
      I had a 2006 Passat come back from a service and that had been over written. There were no software updates available for the car, so the tech must have just carried out the process anyway.
      Re-flashing the ECU is no problem.
        No Charge from APR for the software after a factory reflash.
          unless you're not anywhere near APR dealer
          White 3-dr Polo GTI
          Tiguan 189TSI
            If the car is over 6 months old, the chances of a factory reflash are mighty slim.
            To date, there have been no software updates for Tiguan that we have heard of!
              Has anyone heard of a way to plug a module in with the "reflash", (like plugging in a USB...) instead of the APR permanant system? I have heard that this module can just plug into the diagnostic port when you want it, and just be removed when not wanted.
              The seeming advantage of this is that when we go in to the dealer, we just remove this and they are none the wiser...
              Any thoughts or advantages / disadvantages?
                These sound like the dodgy ebay ones.
                Wouldn't trust it and won't be covered under warranty like APR is by the supplier.
                  I tend to agree, but apparantly someone on our forum sells them? was told who, but cant remember now....
                  I only like the idea of it being removable so it has no chance of being detected. Or do you think it would leave "evidence" when the diagnostics are done anyway?
                  If so, then i would rather stick with the APR and let them detect that more reputable software.
                    When the APR tune is turned off, it can't be detected anyway...
                      I think what you are talking about is something like the Bluefin ST3 which you plug into the OBD-II port (under the steering wheel colsol) and reflash the ECU. You can flash it back to the original mapping when you want. I guess the main issue with it is that there are only so many times the ECU can be reflashed before the cells start to fail. The other concern (which I believe has been fixed now) is that the flash-counter is incremented whenever you remap and VW can detect this. I am told that has been sorted now and the flash-counter is reset after the ECU has been written to. Superchips (who make Bluefin) offer a warranty on the engine for any damage caused by the remap that is not covered by VW. They claim they are the official tuners for the VW racing team in the UK, and that they have never had a claim on the Bluefin warranty for the Tiguan. *shrug*
                      The other thing you my be referring to is something like the DP Chips module. What that does is intercept the signals being sent from the ECU and "adjusts" them to give you more power. Guys in the Club Touareg forum seem to swear by them. This option would be totally undetectable as all you need to do is remove the module from the engine bay and the dealer would be none the wiser. I think it's a higher risk option though due to it's lack of sophistication. Incidentally, I think these are the sort of modules available on eBay.
                      Hope that helps.
                      Tiguan TDI, 6spd Tiptronic Auto
                      Black, sunroof, comfort pack, off-road tech, tan leather, park assist & roof bars.
                      Avg 7.63L/100km over 189,000kms
                        That sure does help...thanks!
                        I guess the best way is indeed the APR method then...
                        It was just the apparant cost savings that first appealed. Although of course we only get what we pay for!
                        APR has been tried and tested I guess.
                          APR remap inside the ECU is invisible to the dealer's diagnostic equipment. They'd have to send the ECU to the factory to interrogate to detect it.
                          Easy way for the dealers to check however (since they all know how it works) is to try the cruise control buttons (which sets the program) in the appropriate manner to see if it responds as when chipped.
                          To prevent even this from happening, get the security lockout, which allows you to lock the setting and then only after entering a PIN will it allow a setting change. This is also undetecable and once locked in this way, there is no way for the dealer to see if you have an APR map loaded.
                          Remember that the reputable tuning houses, spend many hours and $$$ to get the software perfect. Any plugin device (thats stays attached to the system) is suspect as all it does is override some rudementary settings to increase boost, timing an fuel. It is recipe for disaster in the long run.
                          If you car is important to you, I'd suggest you pay for the solution that provides peace of mind and sufficient local back-up support.
                          Current: 2023 MY23 T-Roc R Lapiz Blue + Beats Audio + Black pack 2018 MY19 Golf R manual Lapiz Blue + DAP) 2018 MY18 Golf 110TSI (150TSI) Trendline manual White2014 Amarok TSI Red (tuned over 200kw + lots of extras) 2013 Up! manual Red 2017 Polo GTI manual Black Previous VWs and some others ...
