Hi, I've got a 2010 Tig 147 TSI. I'm trying to diagnose a misfire and need to check the coil pack wiring. To do so I need to pull the fuel pump fuse but can't work out which one it is. The US fuse diagrams say is number 48 , 15A but mine is missing so I'm hoping its in another spot in the aussie fuse boxes. Can someone help me with the diagram or which number fuse it is?
Fuse Diagram Help 2010
chef_32: Hi
If this car has a 2.0L diesel engine, or if it is an early build, try SC47 (15 Amp). My wiring diagram says that the fuse position changed to SC48 for Tiggys built after May 2009
DonPlease don't PM to ask questions about coding, or vehicle repairs. The better place to deal with these matters is in the forum proper. That way you get the benefit of the wider expertise of other forum members! Thank you.
