Hi all,
I've bought a Tiguan 2011 125TSI at 88500km. The Tiggy was well serviced by the previous owner, for instance, Haldex Coupling Oil @ 45k, 84k, Spark Plugs @ 60k, Brake Fluid @ 30k, 60k.
The upcoming service would be, as written down as "oil change" by VW Doncaster from the last service, at 99k or October 2018 (for the 105k interval, I guess). Thanks to tigger73, I'm now aware of the problem with the timing chain tensioner. As a result, I thought it would be good to also inspect the tensioner, and change to the new version as precaution, at the 99k/105k service.
Here is some major tasks I researched around (from vwwatercooled and others) and plan for this 99k (105k) service milestone.
* Oil (Oil + filter change)
* Brake fluid change
* Timing chain tensioner
* Coolant flush
* Transmission (DSG?) oil change.
I will contact a VW Dealer or Independent Specialist for the aforementioned services (other minor things like wipers, air filters I may try on my own).
I would like to hear your suggestion regarding the following aspects:
1. Apart from that, what else would you suggest to combine in this 99k/105k service?
2. What parts of the timing chain tensioner should be changed/upgraded? (Perhaps I will look around to order the parts to save some $$$).
Thank you for your time.
Alex
* Coolant flush
Alex
