I am trying to get tyre pressure and the traffic sign detection displayed on active info display. Anyone ??, please.
My Tiguan has arrived and this is my experience so far
I didn't think road sign detection was available on Australian models. Can't help with tyre pressure monitoring as I don't have my Tig yet.Originally posted by Aus_fas View PostI am trying to get tyre pressure and the traffic sign detection displayed on active info display. Anyone ??, please.
Seems to be - was mentioned in one of the Australian reviews (in the context that it wasn't always detecting the right speed limit).Originally posted by latearrival View PostI didn't think road sign detection was available on Australian models. Can't help with tyre pressure monitoring as I don't have my Tig yet.
2017 Tiguan 162TSI Highline/R-Line
2017 Audi S3
Found it. This one: http://www.motoring.com.au/volkswage...review-105631/Originally posted by Gladbach View PostSeems to be - was mentioned in one of the Australian reviews (in the context that it wasn't always detecting the right speed limit).
"The traffic sign recognition in the Tiguan’s sat-nav system was occasionally fooled by advisory speed limit signs, on occasion posting a ’45’ or ’35’ rather than the ’60’, ’80’ or ‘100’ speed limit zones that actually applied. On one occasion we noted that the system readjusted swiftly after the car was past the road sign in question."
I can't find any other reference to sign recognition anywhere else. I find that paragraph a bit confusing too. Sign recognition is done via a camera not via the sat-nav. Perhaps the reviewer got muddled up with speed limit info contained in the sat-nav maps, rather than by a camera that was reading speed signs by the side of the road.
Sign recognition is done by a camera. The same camera used for lane assist. No lane assist then it's not possible. If it's not activated by default or a driver setting then it can be activated with VCDS I believe.
Tyre pressure monitoring isn't displayed as the system doesn't actually monitor the pressure in the tyre per se. The system works through the ABS sensor on each wheel. When you first get your new car, and whenever you change tyres or change tyre pressures you must initialise the system for it to work correctly. Once it has those "pressures" stored it then very accurately keeps track of the rotational speed of each wheel. A deflated tyre will obviously rotate faster than the system expects it should for a given speed which the TPMS will sense. This will then set off a caution for a deflated tyre and tell you which wheel is affected.
Good to know, thanks for sharing. I'm 99% sure Sign Recognition is not enabled in Australia (but is in the UK & NZ). Here's a thread about trying to enable it: http://www.vwwatercooled.com/forums/...ng-115969.htmlOriginally posted by IsDon View PostSign recognition is done by a camera. The same camera used for lane assist. No lane assist then it's not possible. If it's not activated by default or a driver setting then it can be activated with VCDS I believe.
The Tyre Pressure Monitoring in the Tiguan (or at lest my 162TSI R Line and the 110TSI I have been driving for the past few days) is definitely an active system, it has sensors in all the tyres and shows the actual pressure on the AID and Infotainment System.Originally posted by IsDon View PostSign recognition is done by a camera. The same camera used for lane assist. No lane assist then it's not possible. If it's not activated by default or a driver setting then it can be activated with VCDS I believe.
My old MK6 Golf had the passive system that used the ABS Sensors to monitor a change in pressure and just had a warning light if it detected one wheel spinning at a different speed to the rest.
Sent from my iPhone using TapatalkCurrent Ride: 2019 CUPRA Ateca in Energy Blue with Bucket Seats
My mistake. I assumed it was the same system Audi uses. Thanks for the update.Originally posted by NZ_GolfR View PostThe Tyre Pressure Monitoring in the Tiguan (or at lest my 162TSI R Line and the 110TSI I have been driving for the past few days) is definitely an active system, it has sensors in all the tyres and shows the actual pressure on the AID and Infotainment System.
Does it use senders on the valve stalks like some older systems use or is it built into the wheel? The valve stalk senders were always problematic.
I am pretty sure it uses sensors in the valves:Originally posted by IsDon View PostMy mistake. I assumed it was the same system Audi uses. Thanks for the update.
Sorry, not the best photo but all I had and too dark to take one at the moment.Current Ride: 2019 CUPRA Ateca in Energy Blue with Bucket Seats
Best idea is have a look at the Ross-Tech web site and follow the links to the forums and the wiki. There is also a lot of Ross-Tech videos on YouTube.Originally posted by cvee View PostIs there anyone here who can give a quick summary on the tools related to VCDS? What sort of things can be enabled/disabled? Is there a quick start guide for newbies?
There's lots [emoji16]
Hmmm. Was just there. Very pricey.Originally posted by IsDon View PostBest idea is have a look at the Ross-Tech web site and follow the links to the forums and the wiki. There is also a lot of Ross-Tech videos on YouTube.
What about OBDeleven? Seems the obd2 dongle and software are much cheaper and still allows programming.
Yes, it is pricy. I bought mine when I decided to import a Westfalia tow bar from Europe for my A6 rather than pay $4000 for the Audi piece of **** that passes for a tow bar in Australia.Originally posted by cvee View PostHmmm. Was just there. Very pricey.
The Westfalia (which is a work of art and the OEM bar for Audis in Europe) cost $1000 delivered to my doorstep.
I fitted the bar over the weekend, which included the towing module, but the car wasn't happy. The car had to be coded. Audi wouldn't do it so I had to work it out myself. I then decided the $500 for the Ross-Tech cable was a good investment. Ross-Tech customer service is fantastic. Between them, Westfalia in Germany, and the Westfalia franchise in Australia (that had only just started at that time and weren't yet selling to the public) we managed to work out the coding. About 12 modules had to be tweaked.
So for $1500 total, I had a superior bar fitted, a VCDS cable I've used extensively since, and a whole bunch of knowledge on how these cars work and how much can be achieved with this cable.
I'm sure a lot of what the VCDS does can be done with the OBDeleven, and at a lower cost. I don't know what their relative abilities are. My experiences with the Ross-Tech cable, and their after sales assistance have been very good, and they have been at it a long time. I wouldn't hesitate to go the Ross-Tech option again.
There are countless forums for VCDS tweaks for all VAG models. A cheaper option is to just ask someone with a cable to do the coding for you. I've done a lot of coding for lots of guys for free.
Do you think that enabling significant features that appear to be unavailable in Australia - such as Traffic Jam Assist, Traffic Sign Recognition and Adaptive Lane Guidance - can be turned on with this type of software?Originally posted by IsDon View Post...and how much can be achieved with this cable.
