Since I'm probably going to get into an argument about this with a VW dealer later today, interested in people's thoughts.
Car is an MY20 Tiguan Allspace.
Not long after getting the car I used an OBD11 to make a number of small coding changes (dash graphics, disable seatbelt warning, etc). One of these was enabling the speed limit recognition, which is officially not a feature of AU cars but worked fine (or as well as it does, at least).
About 18 months ago I had a "genuine VW towbar" (yes, I know) installed by $DEALER. This started producing an error on the dash when starting the car "Error: Dynamic Road Sign Display" and the speed sign recognition stopped working. Since it wasn't a major problem, we were leaving on a trip shortly after and $DEALER was a fair distance away I left it to get fixed at some point in the future.
The next service - still not fixed - I asked my regular mechanic to have a quick look and see if he could fix it. He said no, but also highlighted the following fault from a VCDS scan and said it was probably related:
No worries, I thought, I was about to go and get a couple of things fixed under warranty before that expired, I'll get $OTHERDEALER (which is much closer) to look at this and fix it at the same time (because it's a "genuine VW towbar", right
Sadly no joy, they said even though it was a "genuine VW" towbar, they didn't do the install so I'd have to take it back to $DEALER for them to do it.
Now $DEALER is saying they can't/won't do anything because of the coding I've done (specifically the speed recognition, because that's what's appearing on the dash and they have erroneously spent time trying to fix because they didn't actually read the problem I wanted fixed - the fault in the trailer module).
Appreciate this is a bit of a niche question, but has anyone done both of these and can confirm they work together ? Or at least give me some confidence that they're not related in the sense that the speed sign recognition coding is causing the fault in the trailer module.
I have told the dealer all I want them to fix is the fault in the trailer module, but from a somewhat tense conversation late yesterday afternoon, I think they're going to use the speed sign recognition coding as an excuse to either not fix it, or charge $$$$$ (and possibly still not fix it).
Code:
Address 69: Trailer (J345) Labels:I 5O0-907-383.clb
Part No SW: 5O0 907 383 N HW: 5O0 907 383 N
Component: Anhaenger H27 0264
Revision: 8A001003 Serial number: 0537602958
Coding: 0300000202000000
Shop #: WSC 12345 123 61029
ASAM Dataset: EV_TrailFunctGener2Hella 001008
ROD: EV_TrailFunctGener2Hella_VW37.rod
VCID: 42C8B2E9D518108B9F-8016
1 Fault Found:
136203 - Supply Voltage
P1757 00 [00001001] - Open Circuit
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 3
Reset counter: 195
Mileage: 58090 km
Date: 2024.09.06
Time: 10:58:49
).Sadly no joy, they said even though it was a "genuine VW" towbar, they didn't do the install so I'd have to take it back to $DEALER for them to do it.
- I am reasonably sure the speed recognition error coming up on the dash is directly related to whatever the underlying fault being registered with the trailer module is, because it had been working fine before the towbar install and happened straight after.
- I also feel pretty sure the converse is not true, and that the trailer fault identified above is not the product of enabling the speed sign recognition. That said I am basing it on the assumption that "open circuit" is a usefully descriptive error and there is actually an open circuit somewhere that's causing it.
