List of OBDEleven mods and how to do the 30 of them
This is a sticky topic.
  • #31
    Originally posted by Pezzaano View Post
    Spent the night last night going thru a bunch of them on my 2020. So my car is manufacture date 2020, but OBD11 picks it up as a 2021 model. I did not use any apps. I have registered the app and enabled the 2fa as the new instructions to be able to unlock SFD items. So far these ones don't work for my vehicle.
    - engine start stop - as you are aware
    - Needle sweep on startup. Option is there it just doesn't do it.
    - Turn off ignition on chime - all options are there as instructions but the chime is still there
    - Sat nav warning. In coding and in byte 23, all the bit fields are blank so unable to pick which to turn off.
    - Traffic info - In adaptions there is no "change fee bases traffic info" - no big deal there are other means for traffic.
    Anyone had any of these same issues on 2020 models and found work arounds? Cheers
    Well there you go.
    1 Yes
    2 wont do it in Gen 2 aids
    3 reboot head unit
    4 you are looking in wrong place
    5
    • #32
      Originally posted by Hillbilly View Post
      Well there you go.
      1 Yes
      3 reboot head unit
      5
      Edit - Engine start stop works. Tried it again and went for a drive and confirm it does work on my vehicle so very happy about that.
      I'm confused about the wrong place im looking at for sat nav warning. As per your instructions
      Select 5F
      Coding
      Byte 23
      Initial Disclaimer – Off
      Legal Disclaimer – Off
      • #33
        Bought an OBDEleven, and completed these mods over the break on my 2018 162 RLine, best purchase ever!!!
        However I’ve somehow managed to program the fog lights to come on with the regular driving lights, any ideas on how to undo? [emoji1787]
        • #34
          Look in your history and reverse it
          • #35
            Select 5F
            Coding
            Byte 23
            Did you ever figure out the Sat Nav Warning? I have exactly the same issue.
            • #36
              I had figured it out at the start as HE had it on the wrong thing as per his original post
              -"Sat nav warning. In coding and in byte 23, all the bit fields are blank so unable to pick which to turn off"
              and thats why I said what I did
              At the top is a little square with O and 1 in it If the bits were showing HE had it in 1 when it should have been on 0 and would have been in English and simple to do. Same for you its there plain as your face LOL
              • #37
                Hi all, am thinking of selling my Tiguan. Any thoughts on unwinding obdeleven changes? Was thinking of removing the speed sign display as it’s not consistent, but should I remove others? I’ve added the 30 colours, removed the satnav warning, removed the “prevent overtaking a car in the right lane” and a few others. Thoughts?
                May 20 - Nov 19 MY20 Tiguan 162 TSI
                May 16 - Apr 16 Mazda 3 Sp25 GT - 2020 hail storm write-off
                May 13 - 2013 Mk7 Golf Highline.
                May 10 - 2009 Falcon G6E with beige leather.
                • #38
                  I would just leave them as they are "enhancements" rather than "technical or mechanical upgrades"
                  If I was selling mine I would list them and emphasize them as being helpful and if buyers didnt want them would delete as required.
                  The satnav and pass on left is definitely somethings to leave.
                  • #39
                    Hey, does anyone have instructions as to how to undo the steps for dynamic like Assist (DLA)? My fog lights seem to be on constantly now for some weird reason since I did this mod, I have checked 32 times to make sure all the steps are correct from the instructions in the opening post, just want to know what the values were prior to changing them to those settings if that makes sense.
                    • #40
                      You should have the history of what you did and so can reverse it
                      • #41
                        Nice one thank you, took me about half an hour but figured out how to get the history email to myself, how do I know how to change this “new value” back to the “old value” as pictured below?
                        • #42
                          Anyone tried ODB11 coding on a 2022 Tiguan. I've got a 2022 Allspace R-Line (Australian) and some of these tweaks are not available. Module 5F in particular. I can't find how to remove the sat nav nag screen.
                          Also, the ODB11 Forum lists my car as MK2 FL (5N) does this indicate they are aware something is different to the previous MK2 (5N)
                          • #43
                            Getting rid of that is number 5 in my link on the first page. I do wish people would read the thread when someone has taken the time to list all this stuff
                            • #44
                              I've read all your stuff and used the link on your google drive. Appreciate the effort. But that option does not appear on my vehicle. 2022 Allspace. Have you confirmed it works on the latest cars?
                              Select 5F
                              Coding
                              Byte 23
                              ^^^ I don't have those option in my Byte23
                              • #45
                                Select 5F
                                Coding
                                Byte 23
                                Does your screen look like this as thats the one its on NOT the HEX one Look at the little square icon at the top It should be as in my image. And no I havent tried it on a newer car Hence the disclaimer in the 1st post
