List of OBDEleven mods and how to do the 30 of them
This is a sticky topic.
  • List of OBDEleven mods and how to do the 30 of them
    Here is a list of the 31 I have done to my car . I accumulated credits by logging in each day for several weeks and got 6 a day so i could use the apps when needed . Now still have nearly 700.
    Due to VW locking access to modules in 2020 models these probably/possibly wont work on them
    https://drive.google.com/file/d/1XT_...TPRJFZyeG/view
    Have corrected the DLA instructions as I left some of it out
    UPDATED 27/02/21
    Fixed access 3/4/2021
    Thanks for putting this together
    >> 5 Disable Sat Nav Safety Warning
    Would definitely like to go get rid of this annoying nag screen
    >> 14 Adjust speed in Dash to be correct at 100k kph with 20” wheels
    Does this mean our speedo is wrong without this mod ?
    >> 15 Ripping CD _Media _ data
    What does this mod do ?
      Does this mean our OD is wrong without this mod ?
      5 is easy to do
      14 no odo is different to speedo Am yet to run my two cars over a test course to see if it get any difference
      15 allows you to rip a CD into the Media AFAIK have it but havent tried it Will do tomorrow
        Ok heres how to do No 5 Go to Menu/Media/ Settings/ Manage Jukebox.
        Put CD in and it will read it/select source(CD)obviously/go to bottom of screen select import and wait as it does it Takes about 7 minutes.
        It wouldnt do an Audio DVD with 5.1 sound on it
          Originally posted by Hillbilly View Post
          5 is easy to do
          I assume you mean easy with OBD11 as opposed to just doing it via the main Discover Pro Screen ?
          Side note, how much did the OBD11 cost to buy ?
            Yes it isnt in the screen at all as it activates it in the internal coding
            I paid $130 second hand a year ago for a V1 Here is the new one and you DO need the Pro one to do coding
            OBDeleven V2 Pro Pack – Audi, Skoda & Volkswagen Diagnostics – AutoInstruct
            You also need a Android smartphone to run it newer than Android 5.0
            There are cheaper other makes but only that one will do what we want
            Look on Farcebook market place There are NONE on GUMTREE
              Thanks mate. OBD11 was more than I thought these things cost.
              OBDeleven Diagnostic System – Shop – AutoInstruct
              • $209.13 OBDeleven V2 Starter Pack - (Not Pro, 100 Credits)
              • $256.38 OBDeleven V2 Pro Pack - (Pro Licence, 200 Credits)
              • $329.13 OBDeleven V2 Ultimate Pack - (Pro Licence, 500 Credits)
              Couldn't find pricing if you need to purchase additional credits. It only comes with '100 Credits'. Do you use these pretty quick ?
              As I will probably only use the device once not to make some minor mods (disable nag screen etc), not sure if its worth it for me.
              Not sure what this is: OBD-II Engine Code Reader with Bluetooth(R) Technology | Jaycar Electronics
                As the story typically goes, it's hard to stop at just one - they make it too easy to modify further and to stop after only one.
                Credits can be obtained for free by watching ads every day. If you get the pro version, you don't need credits, as you can do the long-coding rather than the apps, which automate the coding process and consume credits to do so.
                  Most apps only use 10 credits and they are about $30 for 75 I think.
                  I spent several weeks logging on every day and let the ads run (30sec each) and you get a credit for loggin in and 5 for the 5 ads I have about 680 atm and i rarely use them
                  The thing from Jaycar is a fault reader nothing else
                  Down load the OBDELEVEN app from the Google playstore and have a look through it
                  Ask on here for some one in your area to do it for you for a slab or something. Each one only takes 5mins at the most
                    Thanks, will check out the apps and see if its better to hit up member with a slab or something.
                    Works out cheaper buying from obdeleven.com - $194 for the OBDeleven V2 Pro Pack - (Pro Licence, 200 Credits)
                    At ~$100 I probably should have bought the OBD11 v1 when I bought the Tig
                    Went through some apps briefly, there were a few.
                    >> Auto Folding Mirrors (App)
                    Is this auto / manual App option not available as default on the Discover Pro Main Screen ?
                      Dunno my mirrors fold from the factory
                      When you work out postage etc its no cheaper
                      If you put your location in your screen sig someone may help.. Australia isnt very specific is it
                        Same with mine. I assume its the right door switch that does this so not sure what this app does ...
                        The $194 was in AUD (€117.99) including postage to AUS as per obdeleven.com
                          Here is a list of the 30 I have done to my car . I accumulated credits by logging in each day for several weeks and got 6 a day so i could use the apps when needed . Now still have nearly 700.
                          https://drive.google.com/file/d/1XT_...ew?usp=sharing
                          Hi Hillbilly,
                          How does the Dynamic Light Assist mod work without the right spec of hardware?
                          My understanding was this system partially masks the main beam of the headlight to avoid dazzling oncoming cars, I didn’t think this could simply be activated without the right type of headlights.
                          Light Assist on the other hand is an automatic on/off for the high beam using the camera detecting oncoming cars.
                            Originally posted by bor1203 View Post
                            Hi Hillbilly,
                            Correct on both counts Without the correct headlights DLA wont work
                            All work on top spec models like mine so I cant vouch for others Definitely wont work with Halogens
                              Originally posted by southtig
                              In investigating a my20 purchase I checked the obd11 official word on this and they say that VW has told them they will have access to my20+ cars but they are waiting on VW providing them access/process docs to do so. To me that sounded vague as hell, and after them not providing any real updates for many months I would suggest that people count on these not working any time soon.
                              Actually has been quite a few new apps been added in recent weeks but even the simplest ones appear not to work on MY20's
