Speedo Correction Is it possible
  • Speedo Correction Is it possible
    Wondering if its possible, using an OBDeleven to alter the pulses or however the speedo is calibrated on the Tiguan.
    Am sick of running close to the wind when using ACC with the little hard to see Speed camera trailers on the Bruce north of Brisbane.
    I couldnt do it on the Passat so hoping for better with this one
    I doubt it.
    My Tig is about 3-4 km/hr lower at 60kph
    2018 Allspace 162TSI R Line
      What you need to do is have an OBD reader and display ECU speed. This is accurate.
      Autopolar FIS+ will do it.
      - Tigger73's 125TSI Build
        Yeah I can do that with my OBD11 but as with other VW models there is usually a way to alter the pulses per Km to get it closer to actual
        The Passat had 5 different country settings and would accept the VCDS changes but never actually did them
        The Polo was the same Had several different settings between 0 and 7 for pulse rates and accepted them but didnt change anything.
        I just wondered with the more sophisticated modules in the Tigs if it was possible or if anyone had investigated .
        Mine reads 4 over actual at 100kph and about 5 at 110. I went past a speed camera the other day and on reading my dashcams I was doing 112 when I had ACC set at 116. Was 24 days ago and ticket hasnt shown up so far LOL
        Cant be fussed having to read it off the phone all the time. At least the Passat showed it in the secret menu in the RNS510
          I get what you mean, but can’t you just set the cruise to a speed that you know is safe- but not too slow? I know my speedo is currently 4% out, so as a buffer I set it to 114 on 110 zones and 104 for 100.
          This puts me basically at the true speed limit.
          There’s then about 3-6kph(depending on state) buffer allowed for camera variance vs true speed. Ie- if you’re pinged for 103 in 100 zone, you were really doing 106-109.
            Yes and thats what I did as I said but was being a bit greedy and had it at 116 which is 1- 2 over true . It would be much easier if it was just correct as it was in my Landcruiser..
            You dont get any buffer like 6 in Qld Probably 3 max as I got a ticket years ago for 4 over.
            Camera is sitting on the top of a hill so most cars slow a bit but not VW it just keeps on keeping on at the set speed Damn it Lol
              I read that Queensland govt were buying extra little yellow trailer speed cameras because the first two were the most revenue productive speed cameras in the State. I have seen them amongst the Gateway and EightMilePlains roadworks behind the temporary barriers with just the camera snorkel above the barrier.
              Agree the VW built-in speedo error is a pain. Its worth a good half an hour driving Brisbane to Sydney.
              We have gone into work-around mode with a Garmin GPS suction-cupped to the windscreen which appears to be real-time accurate, and just set CC to that.
              I have been into fuel economy lately and a few clicks lower can make a big difference, so I tend to focus on that. Almost as much fun...
              MY09 Golf Candy White 2.0 TDI Pacific
              MY95 Golf III TDI
                Don't forget to keep the following in mind, not VW's fault:
                Vehicle Standard (Australian Design Rule 18/01 - Instrumentation) 2006 and still in force
                18.5. SPEEDOMETERS AND ODOMETERS (ALL VEHICLES)
                18.5.1. Speedometers
                18.5.1.1. Unless otherwise ‘Approved’, every vehicle shall be fitted with a speedometer which shall:
                18.5.1.1.1. indicate vehicle speed only in kilometres per hour; and
                18.5.1.1.2. indicate the actual vehicle speed, for all speeds above 40 km/h, to an accuracy of + 10 per cent.
                18.5.1.2. The speedometer shall be installed so that its indication is readily visible to the driver when seated in the normal driving position.
                18.5.2. Odometers
                18.5.2.1. Every vehicle other than LA; LB and LEM group vehicles shall be fitted with an odometer which shall:
                18.5.2.1.1. indicate distance travelled in one kilometre units (or less) from 1 to 999,999 kilometres; and
                18.5.2.1.2. indicate the actual distance travelled by the vehicle to an accuracy of + 4 per cent.
                18.5.2.2. Every vehicle of category LC, LD and LEM shall be fitted with an odometer which shall:
                18.5.2.2.1. indicate distance travelled in one kilometre units from 1 to 99,999 kilometres; and
                18.5.2.2.2. indicate the actual distance travelled by the vehicle to an accuracy of + 4 per cent
                  Snip
                  You are preaching to the converted.
                  I have quoted that myself dozens of times and doesnt alter what I asked. You can still have it reading exact speeds, but not under.
                  My speedo and all VW speedos are legal but i want it closer to reality if possible. Im not really het up about it but would be nice if someone has worked out how to bring it closer
                  As far as Im aware its up to 10% + -4 at 100kph as well if expressed in simple terms
                  Speedometer Accuracy - Speedo Regulations - RACQ
                  Vehicle Standard (Australian Design Rule 18/03 - Instrumentation) 2006 is applicable
                    Please be careful using a GPS for your speed, as it is only accurate on a level surface, when going up or down hill it is not accurate.
                      I might be a little lost here but why do people treat GPS speed as reliable for day to day driving? I can understand smashing it down a straight road, that would be pretty accurate. In normal driving conditions with the GPS having to plot your position and measure the time over distance to calculate your speed, I don't see how that can be accurate. In indicative figure, yeah. You'd be varying your speed for traffic, corners etc. Surely the GPS can't output an accurate figure if you're doing that.
                      Then again, I'm no GPS expert!
                      MY19.5 Tiguan Highline with R-Line & Sound/Vision
                        Read this then and learn LOL
                        To calculate the Longitude, Latitude and Height position, a GPS receiver precisely measures the different speed of light (299,792 km/s) delays in the signals coming from 4 or more satellites. The distance to each satellite is calculated, and then using trilateration, the 3D position of the GPS antenna is calculated.
                        How GPS Receivers Work | HowStuffWorks
                        As far as how often it does it, its almost instant so as you slow your car so does the reading Its not like it updates ever 30 secs or something
                          Have been looking through the modules in my OBDII and in the ECU I notice there is a long coding one called WHEEL CIRC.
                          I wonder if altering that will fool it into doing less impulses per KM.
                          I havent connected to the car to see what happens if I open it up
                            It is quite common in the southern parts of Oz not to lock onto four satellites, we encountered this many times when data logging race cars and the Tiguan never tells you how many satellites it has access to where we could see it against the data. GPS signals available to non military users works to a tolerance which varies when it gets manipulated by the US authorities so when that happens the accuracy wanders around. We used physical sensors and overlaid the data with GPS and the GPS ALWAYS lagged in both speed and other readings without fail. I have connections with a family company which designs and builds this stuff and believe me it ain't fool proof until you get into the military grade GPS which they do.
                              To answer your question, "Is it possible?" Probably. Should you do it? Probably not.
