Originally posted by Simonr23
View Post
Brake Pedal too far forward - anyone else have this issue ?
Think he needs a good DPF delete, EGT delete, all that BS coded out, a bit more boost and instant boners (just pray the car doesn't die because warranty is out the door).Daily 2018 Tiguan MK2 Sportline (Drag & Drop Tune, 12.9s @ 108mph)
Weekend/Track 1996 Skyline R33 GTS-t Stage 99 (Built Motor, GTX3576 Gen 2, 407rwkW) [Build Thread]
www.nhbautomotive.com.au
Originally posted by Dose Pipe Sutututu View PostThink he needs a good DPF delete, EGT delete, all that BS coded out, a bit more boost and instant boners (just pray the car doesn't die because warranty is out the door).2021 Kamiq LE 110 , Moon White, BV cameras F & B
Originally posted by Simonr23 View PostI wish I had bought the 162. I really thought the diesel would have the better low end. I was so, so wrong. I have no bottom and top ends (top end expected, and for a diesel it’s ok) Lose, lose!
If I had, I’d probably be able to be a bit more positive. I agree, the ‘feel’ of the car is nice.
Transporter, I welcome you to drive my car and feel for yourself. If I recall, we live close to each other (southern suburbs Adelaide)
Coming from gu patrol (2.8 too) a td5 discovery, and the car immediately before this- a gj Mazda 6, this engine is quite a bit different. Perhaps not as bad as the patrol, from 800-1600rpm, but so close it’s not funny.
Originally posted by Grugly View PostIt's also illegal to remove the cat but people do that too [emoji2373]
Sent from my SM-N950F using Tapatalk
And I don't seem to have that brake pedal problem.Daily 2018 Tiguan MK2 Sportline (Drag & Drop Tune, 12.9s @ 108mph)
Put it this way, the brake pedal being a "bit" forward will prevent some drivers stepping on both the accelerator and brakes at the same time (benefit to most, however in a race car situation you won't be able to heel & toe)Daily 2018 Tiguan MK2 Sportline (Drag & Drop Tune, 12.9s @ 108mph)
