Brake Pedal too far forward - anyone else have this issue ?
  • #31
    Originally posted by Simonr23 View Post
    I wish I had bought the 162. I really thought the diesel would have the better low end. I was so, so wrong. I have no bottom and top ends (top end expected, and for a diesel it’s ok) Lose, lose!
    If I had, I’d probably be able to be a bit more positive. I agree, the ‘feel’ of the car is nice.
    You must belong to a tiny minority of diesel owners who aren’t happy with the diesel performance. Most diesels achieve peak torque right from the 1500rpm.
    • #32
      Think he needs a good DPF delete, EGT delete, all that BS coded out, a bit more boost and instant boners (just pray the car doesn't die because warranty is out the door).
      Daily 2018 Tiguan MK2 Sportline (Drag & Drop Tune, 12.9s @ 108mph)
      Weekend/Track 1996 Skyline R33 GTS-t Stage 99 (Built Motor, GTX3576 Gen 2, 407rwkW) [Build Thread]
      www.nhbautomotive.com.au
      • #33
        And so is roardworthyness as it is totally illegal to remove the DPF
        • #34
          It's also illegal to remove the cat but people do that too [emoji2373]
          Sent from my SM-N950F using Tapatalk
          • #35
            I dodged a bullet there. I had a 125TDI Superb and naturally thought a 140TDI Tiguan should blow it away. A short 2km drive was all I needed to prove that was not the case at all and the 162 was the better car even though at that stage I had not driven a 162 as there were none in the country. The 125 was light years faster and more responsive than the 140 and I am convinced the 125 had more KW than the badge said.
            • #36
              Transporter, I welcome you to drive my car and feel for yourself. If I recall, we live close to each other (southern suburbs Adelaide)
              Coming from gu patrol (2.8 too) a td5 discovery, and the car immediately before this- a gj Mazda 6, this engine is quite a bit different. Perhaps not as bad as the patrol, from 800-1600rpm, but so close it’s not funny.
              • #37
                Even running a stock cat with a reflash, I suspect you would fail the IM240 gas test.
                And I don't seem to have that brake pedal problem.
                • #38
                  Interesting (and funny) thread.
                  After driven nothing but Toyotas for 10 years I did observe that the brake pedal felt further forward and remember having a whinge about it to friends.
                  I've learned to deal with it and have moved on.
                  Arteon & T-Roc
                  • #39
                    I’ve owned over 30 cars. Different models within the same brand will have different brake pedal heights, let alone between brands. Me thinks the complainers need to get out more
                    • #40
                      Put it this way, the brake pedal being a "bit" forward will prevent some drivers stepping on both the accelerator and brakes at the same time (benefit to most, however in a race car situation you won't be able to heel & toe)
