What is the best Engine Oil for the 2019 VW Tiguan 162TSI Rline for top ups ?
2019 VW Tiguan 162TSI Rline - what is the best Engine Oil for top ups ?
The same oil that's in it
Castrol Edge Long Life that's VW 504/507 compliantDaily 2018 Tiguan MK2 Sportline (Drag & Drop Tune, 12.9s @ 108mph)
Weekend/Track 1996 Skyline R33 GTS-t Stage 99 (Built Motor, GTX3576 Gen 2, 407rwkW) [Build Thread]
www.nhbautomotive.com.au
Thanks DoseOriginally posted by Dose Pipe Sutututu View PostThe same oil that's in it
Searching, there seems to be ones with similar names. Is the one at SCA the same that you are referring?
Castrol EDGE Professional LongLife III 5W-30
CASTROL EDGE 0W-40 A3/B4
Supercheapauto Castrol Edge Engine Oil - 0W-40 5 Litre - $88.99
Make sure it has LL at the end of the viscosity rating as these cars do have a long service interval.
The ones you've listed aren't the correct oils as they aren't VW504 / VW507 compliant. They're VW502 / VW505.
The below is the one that's correct for our cars, albeit it says diesel.
Castrol Edge Diesel DPF Engine Oil - 5W-30 LL 5 Litre | Supercheap Auto
I actually bought Penrite Enviro+ 5W30 for my next oil change, I'm a bit of a Penrite fan
Penrite Enviro+ Engine Oil - 5W-30 5 Litre | Supercheap AutoDaily 2018 Tiguan MK2 Sportline (Drag & Drop Tune, 12.9s @ 108mph)
I assume any VW504 / VW507 will do ?
SHELL HELIX ULTRA ECT 5W-30
Specifications: BMW LL-04; MB approval 229.51; VW 504.00/507.00; Porsche C30
SuperCheapAuto - Shell Helix Ultra ECT C3 Engine Oil - 5W-30 5 Litre - $69.99
Volkswagen 504.00/507.00 Approved Oils
Volkswagen Oil Standard 504.00 / 507.00 Approved Oils
BP BP Visco 7000 Longlife III SAE 5W-30 50400/50700 Castrol Castrol Edge SAE 5W-30 50400/50700 Castrol Castrol Edge 5W-30 SAE 5W-30 50400/50700 Castrol Castrol Longlife III SAE 5W-30 50400/50700 Castrol Castrol SLX Professional LL03 SAE 5W-30 50400/50700 Castrol Castrol SLX Professional Longlife III 5W-30 SAE 5W-30 50400/50700 Castrol Castrol SLX Professional Powerflow Longlife III SAE 5W-30 50400/50700 Castrol Castrol SLX Professional Powerflow Longlife III 5W-30 SAE 5W-30 50400/50700 Castrol Castrol TXT 507 00 SAE 5W-30 50400/50700 Mobil Mobil 1 ESP Formula SAE 5W-30 50400/50700 Mobil Mobil SHC Formula V SAE 5W-30 50400/50700 Mobil Mobil Super 3000 Formula V SAE 5W-30 50400/50700 Pennzoil Pennzoil Platinum VX SAE 5W-30 50400/50700 Pennzoil Pennzoil Platinum VX SAE 5W-30 50400/50700 Pennzoil Pennzoil Ultra Euro L SAE 5W-30 50400/50700 Penrite Oil ENVIRO + SAE 5W-30 50400/50700 Shell Shell Helix Diesel Ultra Extra SAE 5W-30 50400/50700 Shell Shell Helix Diesel Ultra Extra SAE 5W-30 50400/50700 Shell Shell Helix Ultra AV-L SAE 5W-30 50400/50700 Shell Shell Helix Ultra AV-L SAE 5W-30 50400/50700 Shell Shell Helix Ultra Extra SAE 5W-30 50400/50700 Shell Shell Helix Ultra Extra SAE 5W-30 50400/50700 Shell Shell Helix Ultra VX SAE 5W-30 50400/50700 Shell Shell Helix Ultra VX SAE 5W-30 50400/50700 Valvoline Valvoline SynPower XL-III SAE 5W-30 50400/50700 Volkswagen Original Teile ® LongLife III Hochleistungsmotorenöl SAE 5W-30 50400/50700 Last edited by FastMitch; 25-04-2019, 09:52 AM.
It quite plainly says on the rear of the bottle if it is VW APPROVED
The two links above are dead right and I usually use Penrite Enviro+ NOT THE +10 version Look on the label as i said
However due to an error on Supercheaps website I scored 10L of the Castrol for $75 a couple of weeks ago
Petrol engines can use 502/505 oil but it doesnt hurt to use a better grade and as up till this month I had a petrol and a diesel so used the higher grade in both
EDIT AFTER YOU POSTED
If its got VW APPROVED on the bottle its OK
if its got SUITABLE FOR or nothing referring to VW ITS NOT
Several containers look identical so always look at the specs labelLast edited by Guest001; 25-04-2019, 09:50 AM.2021 Kamiq LE 110 , Moon White, BV cameras F & B
I recently bought the Castrol one you linked- it is currently half price at SCAOriginally posted by Dose Pipe Sutututu View PostThe below is the one that's correct for our cars, albeit it says diesel.
Also, when I asked where the oil was the guy at SCA mentioned he personally uses the Penrite too...2018 Allspace 162TSI R Line
The one thats half price is a 502/505 A3 B4 grade oil for petrol engines OR Diesels WITHOUT a DPF as per hereOriginally posted by iDiesel View PostI recently bought the Castrol one you linked- it is currently half price at SCA
Castrol Edge Engine Oil - 5W-30 5 Litre | Supercheap Auto
but is NOT approved for a Tig petrol motor other than to use .5 of a L to top it up in an emergency
In the MANUAL that book still in the plastic it says that the correct oil that the vehicle has been filled with is on a sticker beside the bonnet lock.
I have just looked and my 162 has 504/507 on it so I wont be buying the half price stuff however tempting it is.
The 504/507 oil has an orange sticker with DPF Compatible on it at the top of the label as per here
The two LL's make a L of a difference and should be used as per your manual.Last edited by Guest001; 25-04-2019, 07:34 PM.2021 Kamiq LE 110 , Moon White, BV cameras F & B
Race car gets Penrite, wife's car also will get Penrite lolOriginally posted by iDiesel View PostI recently bought the Castrol one you linked- it is currently half price at SCA
Also, when I asked where the oil was the guy at SCA mentioned he personally uses the Penrite too...Daily 2018 Tiguan MK2 Sportline (Drag & Drop Tune, 12.9s @ 108mph)
Originally posted by Dose Pipe Sutututu View PostRace car gets Penrite, wife's car also will get Penrite lol
Its not so much the brand as the correct type and viscosity that matters
However I agree with using Penrite as mine have been on it since new 8 years ago2021 Kamiq LE 110 , Moon White, BV cameras F & B
sorry, yes you are right. That’s not the one I boughtOriginally posted by Hillbilly View PostThe one thats half price is a 502/505 A3 B4 grade oil for petrol engines OR Diesels WITHOUT a DPF as per here
Castrol Edge Engine Oil - 5W-30 5 Litre | Supercheap Auto2018 Allspace 162TSI R Line
So which one did you get for half price I got the correct stuff but was due to someone stuffing up an ad on the net but they honoured it for meOriginally posted by iDiesel View Postsorry, yes you are right. That’s not the one I bought2021 Kamiq LE 110 , Moon White, BV cameras F & B
You are incorrect read what it says in the link, as Professional III is what the dealers use and is a 504/507 grade and IS APPROVED by VW and VW vehicles in AUS are NOT on a longlife service plan They are ALL 12 months or 15,000km whichever is first. I also doubt that oil being available in any shop as in 8 years I have only ever seen it available at a dealers at $93 for 5 LOriginally posted by Dose Pipe Sutututu View PostMake sure it has LL at the end of the viscosity rating as these cars do have a long service interval.
Penrite Enviro+ Engine Oil - 5W-30 5 Litre | Supercheap Auto2021 Kamiq LE 110 , Moon White, BV cameras F & B
Yes I am very aware of thatOriginally posted by Hillbilly View PostIts not so much the brand as the correct type and viscosity that matters
The Skyline gets 15W50, but it has had its rings gapped at 0.005 for both rings.
Shetbox Tiguan gets 5W30 as that's what it takes for now, until the motor gets sloppy then it's 40 weight.Daily 2018 Tiguan MK2 Sportline (Drag & Drop Tune, 12.9s @ 108mph)
