2019 VW Tiguan - Where is the Mute Button ?
  • 2019 VW Tiguan - Where is the Mute Button ?
    2019 VW Tiguan
    Does anyone know where is the Mute Button for the Music ?
    I couldn't see it on the steering wheel
    There’s not one - at least not on the R-line wheel
    If you have theDiscover Pro centre entertainment system, you’ll need to turn volume down by volume buttons or press the radio power power for about 2 secs
    2018 Allspace 162TSI R Line
      Very disappointed such a basic feature is not available
      Even my old SUV has a mute button
        Press the power button.
        A light push should mute, if you hold your finger it will cycle to a clock and if you keep holding it the unit will do a hard reset.
        Sent from my SM-N950F using Tapatalk
          Mazda don’t have one either. Common place it seems.
            The engineers probably don't think you need one. If your phone is paired to the entertainment unit it will mute it when the phone is active. Passengers shouldn't be touching buttons on the steering wheel...
            If your phone isn't paired you shouldn't be using it.
            So they figure it's a redundant feature.
            2015 Jetta Highline
            2017 Ducati Supersport S
              Nice idea, but if I am using Sat Nav I don't want to turn off the Unit just mute the volume.
              I thought there was a mute option in the Tiguan 2018 version. Maybe I am mistaken.
                Tapping the power button mutes music but keeps the screen on. So it won't impact the nav screen
                  Thanks - I will try that tomorrow
                  If only there was some secret function on the Rline steering wheel
                    There is.
                    Long press the volume down button on the wheel.
                      Tried that and all it does is slowly decrease the volume
                      It does not act as a mute function that then returns to the last volume after de-activating
                        There is.
                        Does that rapidly reduce the volume, or simply mutes the audio?
                          Long press on steering wheel button does not mute the audio, just reduces the volume
                            Thanks Grugly - that worked well
