Has anyone done a direct comparison between the standard non ACC suspension and the 3 settings on the newer Highlines? Our 2017 non ACC Highline rode a lot firmer than expected and both the Passat and golf Alltrack hire cars I tried handled speed bumps and potholes in a more composed manner. I'm wondering whether comfort mode has improved the urban ride in the newer Highlines?
Adaptive chassis control
I can feel the difference in the suspension from comfort, normal and sport.
I use individual, steering in sport, everything else in normal most of the time, steering in normal is too sloopy.Tiguan Gen2 162TSI Etuners IS38 Stage 3 238.6 kw@4 wheels
I installed Eibach variable rate springs and that has helped all 3 modes.
Comfort mode used to have too much body roll - springs have lessened this with no real change to the ride quality.
Normal mode is still the best for my daily driving - is a bit less body movement and still good ride quality.
Sport mode used to be way too bumpy. Springs have smoothed out the smaller sharp bumps and improved the ride quality.
With the change for MY19 to 19" wheels for the Highline I suspect that's the reason why VW has also added the adaptive suspension to allow people to adjust the ride to compensate for the harsher ride of the lower profile tyres on the 19's.
I really think it's hard to compare the ride quality of the MY17-MY18 with 18" wheels to the MY19 with 19" and the adjustable dampers.
If you think the ride is too firm you could always look at putting a set of 17's on with higher profile tyres... or changing the springs.
I am curious, how often does it get changed? In our Golf P hardly ever, the only time I change it in that is in the wet and I will soften it right off. I decided not to get it in the Tiguan and have not noticed anywhere where it might be useful but I drive in the bush mostly on open roads so maybe that is the reason.
I drive in Comfort on longer trips on the highway. Around town is “normal” and if I want to go for a bit more of a spin I’ll stick it on sport.
Went down the great ocean road recently, put TIG in sport which made a good difference, been on some dirt roads in Dalesford and used the offroad setting which dampens the throttle..
On the odd occasion someone wants to have a traffic light GP with me switch to Sport and ESC off.Tiguan Gen2 162TSI Etuners IS38 Stage 3 238.6 kw@4 wheels
I never considered changing springs, it's a good idea but I won't be modding my current Tig as I'll be getting rid of it soon.Originally posted by tigger73 View PostI installed Eibach variable rate springs and that has helped all 3 modes.
Can you give us the Part Number for this - as I noticed that Eibach have two different codes for the Fronts.
EDIT
Sorry should of looked at the Aus Eibach site, and read a few more threads.
It seems like this is the the one for the Highline with Electronic Dampeners.E10-85-043-05-22
Last edited by davman; 07-08-2019, 10:29 AM.2019 MY19.5 Highline (R-Line, S&V, Sunroof)
Stage 3 - Etuners Motorsport - 228wkW, TCU Tune
G Revision IHI IS38, BMS Panel Filter, CTS Turbo Elbow, CTS Downpipe, Dogbone Insert
Dynamic Light Assist (OBD11), Eibach Pro Kit Suspension
I would be interested in getting perspectives on the different aftermarket suspension setups that you guys have gone with - specifically with the ACC - Electronic Dampeners.
I have noted that INASNT has H&R Springs, and Tigger73 has Eibach Springs (and a few more are getting Eibach I notice)
So why have you done this upgrade, and what benefits have you noticed - I appreciate some comments have already been noted, but some others may have some extra points to discuss.2019 MY19.5 Highline (R-Line, S&V, Sunroof)
For me, coming from a small Toyota Corolla hatchback, there was just far too much 'give' with the stock suspension for the Tiguan. Going over a speed bump felt like i was on a dinghy in the middle of the pacific - far too much vertical movement.Originally posted by davman View PostI would be interested in getting perspectives on the different aftermarket suspension setups that you guys have gone with - specifically with the ACC - Electronic Dampeners.
Changing up the springs firmed it all up and is now much more familiar. Emphasis on familiar, as comfort is specific to the individual.
However, by far the biggest incentive for me to change springs was for aesthetics. That's the biggest difference between the H&R and Eibach IMO. H&R springs are lower, whereas Eibach maintains the OEM look whilst providing enough of a height reduction.
I changed mine for looks, better handling and for a more firm ride. I used to drive with suspension in sport all the time as normal and comfort were too floaty, I also have the steering on sport.Originally posted by davman View PostI would be interested in getting perspectives on the different aftermarket suspension setups that you guys have gone with - specifically with the ACC - Electronic Dampeners.
With the H&R I drive with suspension in normal now and it rides so much flatter and more controlled and felt more like my gold r with stock springs.Tiguan Gen2 162TSI Etuners IS38 Stage 3 238.6 kw@4 wheels
