2019 VW Tiguan Wolfsburg Edition - Review
"Access to the boot is aided by a button on the driver’s door which lifts the power tailgate, but for safety reasons doesn’t close it back up - you’ve gotta get out and do that yourself with another button located on the underside of the boot lid."
Is this correct ? I thought you could close the boot from the drivers seat button ?
"However, at low speeds or coming to a stop, you can feel the transmission hesitate and shudder slightly, a recognisable feeling for anyone accustomed to Volkswagen’s dual clutch transmission."
I didn't experience any shudder when test driving a Highline from the dealership. Has anyone else experienced this ?
"The stop-start function is much better than others on the market, but still not as smooth as it could be, and if you’ve got the auto hold (parking brake) on while stopped, there’s a noticeable jolt and sometimes a delay when you accelerate to start moving again which can be annoying."
Stop-start seemed to work perfectly for me in the Highline test drive. Did anyone else experience issues with Stop-start ?Last edited by FastMitch; 04-01-2019, 11:05 AM.
Originally posted by FastMitch View Post"Access to the boot is aided by a button on the driver’s door which lifts the power tailgate, but for safety reasons doesn’t close it back up - you’ve gotta get out and do that yourself with another button located on the underside of the boot lid."
Boot lid - just use the open/close function on your key.
Dsg shudder - might happen now and again on certain inclines/declines. TCU tune has fixed 99% of all the dsg quirks and made it awesome to drive in D, refer “Tiguan IS38 and big turbo upgrades” thread for initial review.
Start stop- use VCDS or OBD11 to disable this function.
Happy days!VW Tiguan 162 TSI Highline w/ R-Line & DAP. Mods: OEM IS38 turbo, APR IS38 98 RON ECU tune, TVS Stage 2 + with custom TCU tune, APR Downpipe and resonator delete, APR turbo inlet, VWR turbo muffler delete, APR pendulum mount, APR dog bone insert, APR Open Pod Filter (MQB), RAMAIR intake tube, APR Red Ignition Coils, NGK R7437-9 Spark Plugs, DBA T3 slotted rotors front and T2 slotted rotors rear, ATE ceramic pads front and rear Vbox: 0-100 4.1s
1. Wouldn't you be opening the boot to have someone gain access.. you should have someone there to push the button closed 99% of the time unless your opening it for someone extremely short.
2. Yes, under heavy load I find a slight "shudder" but does not impact acceleration or the operation of the vehicle and last's less than a second.
3. I don't mind stop start and as stated it is much better in this current gen as it uses the radar to turn off the engine at low speed when you are applying the brake and it detects a stationary objective in front of you. Also, restarts the engine when it detects the car in front move forward or motion in front so most times in stop start traffic it will work without issue.. it is still annoying at roundabouts or when you need quick reactionary acceleration but I push the button to turn it off when I know that is needed.
Sent from my SM-N950F using Tapatalk
Originally posted by Grugly View Post1. Wouldn't you be opening the boot to have someone gain access.. you should have someone there to push the button closed 99% of the time unless your opening it for someone extremely short.
Seems 7 seat version you can close from the Drivers dash
YouTube
VW Germany says you can close from the Drivers Seats
YouTube
And this
Electric tailgate help - VW Tiguan MK2 Forums
I wonder if this can be changed with a VCDS change ?Last edited by FastMitch; 04-01-2019, 02:28 PM.
