Originally posted by Maximilium
View Post
hardwiring to fuse on tiguan
That's what I thought until I try it on my Tiguan.... the position of the cable on the fuse tap was preventing insertion on the one I wanted to use, I try a different one for the small fuse, it keep coming loose... the fact that the fuse box is in front of the driver side storage compartment don't make things easier either (fuse tab cable can rub against door).Originally posted by Hillbilly View PostWhy wont a fuse tap work Does one every other vehicle in the world
You can use mini taps in Micro fuses. Had to do it in my Sons Fiesta and if it doesnt fit one way just turn it around the other wayOriginally posted by Maximilium View PostThat's what I thought until I try it on my Tiguan.... the position of the cable on the fuse tap was preventing insertion on the one I wanted to use, I try a different one for the small fuse, it keep coming loose... the fact that the fuse box is in front of the driver side storage compartment don't make things easier either (fuse tab cable can rub against door).
Its not recommended but will still work ,only difference is that the voltage goes through the original fuse and then back to the camera.
Far better than splicing into circuits on a VW as it can shut them down if computer senses incorrect values in a circuit.
You do realise there are 3 different size fuses Standard mini and micro The spacings on mni and micro are the same as I found after i bought some micro taps and had a hell of a job trying to insert it Had put a mini in temporarily and ended up just using that. 2 months later still working OK2021 Kamiq LE 110 , Moon White, BV cameras F & B
I order all 3 sizes.. didn't work for me.. mini tabs vibrate loose turning off my radar detector randomly (possible bad quality tabs).
So I waited until I got all the parts for a modification I made to the car (Auto Disable engine stop-start system) end it up taking the power directly from the accessory 12v
