Hi guys silly question but does anyone know how to turn off the drl while ignition is on thanks
How to switch of drl
Source - A guide to enable EU specific features for AU Spec TiguansEnable/Disable Daytime Running Lights in Discovery Head Unit
- Go into Module 09 Central Electronics
- Select Adaptations, then Aussenlicht Front
- SelectTagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich
- Set value to Active. The default is "not active"
- Click on accept, and enter 31347 as the security code.
- From the Discovery head unit, select Car, then Setup
- Select Light, and you should see Daytime Running Light as an option
Note, with this change, you turn on the DRL from the Discovery Media, not from the light switch. The light switch can be set to 0 and the DRL will still be controlled from the head unit.
