thanks drivesafe
Beach driving - off road modes
It depends on your definition of off road, some reckon that is any road that is not sealed, mine is it is off road if you might need a winch. Mine has been on a lot of unsealed roads with big rocks in some places and it is this type of surface that damages rims and tyres and is precisely why I didn't order an R Line with low profile tyres. I lightly touched a traffic island in our Golf Performance some time ago, exit one rim which can be repaired but the care needed to avoid this sort of stuff is just stupid.Originally posted by drivesafe View PostHi Moose, Tigs come with both high and low profile tyres, and if you are not sure what you have, post up your tyre dimensions here.
I made it a requirement for my Tig to have high profile tyres so I could try it off road, but after nearly two years of ownership, I still have not had the time to try it off road.
Has anybody had theirs off road, other than sand driving?
Anything under 65 is starting to get to be low profile Cruisers use 70 or 75 for a reasonOriginally posted by anonymousmoose View PostExcuse my or ignorance. Is it correct that my standard highline tyres are not low profile?2021 Kamiq LE 110 , Moon White, BV cameras F & B
Some light muddy forest trails may be OK, but I wouldn't risk it with much more than that.Originally posted by drivesafe View PostHas anybody had theirs off road, other than sand driving?
Plus the 4 Motion isn't quite true 4WD, plus low clearances mean, I'll just stick to beach driving.2018 Allspace 162TSI R Line
So reporting back - the tiguan drives nicely down the beach as long as its hard, as soon as there is a little bit of loose sand on the surface the wizards kick in and without moving the throttle position power is all but cut. I first noticed after happily driving down the beach then going to park up the beach where its a bit softer, lucky i had i bit of a run up.
The real issue was after a weekend of people driving past our camp site, the beach was relatively churned up, and i got bogged simply trying to drive back down the beach onto the hard sand - getting caught up in the tracks. i can't stress enough how much the throttle automatically cuts out when you need it to just keep going. so now I've lost all momentum and stopped. to try to keep going i ease on the throttle, slowly more and more, nothing is happening until boom, 3 jets of sand 3m in the air. The max tracks were useless, as the nothing nothing everything meant i simply burnt the knobs of the tracks. i ended up being being pulled out by a hillux that had no trouble getting around, was even towing a camper up the beach no trouble.
It could be that I’m absolutely useless, my last suv was a Freelander2 and i couldn’t get that thing bogged even when i tried.Last edited by craig_perth; 19-10-2018, 01:05 AM.2018 R-line Tiguan DAP
Did you have the traction control turned off?Originally posted by craig_perth View PostSo reporting back - the tiguan drives nicely down the beach as long as its hard, as soon as there is a little bit of loose sand on the surface the wizards kick in and without moving the throttle position power is all but cut. I first noticed after happily driving down the beach then going to park up the beach where its a bit softer, lucky i had i bit of a run up.
Sounds like traction control stepping in, happens on all 4wds no matter the size. It must be turned off every time you turn the car off and back on again as it automatically comes back on
^ This!!Originally posted by Oz85 View PostDid you have the traction control turned off?
I took ours to Capertee and it was pouring rain, so I turned off traction control and spun all four wheels in the mud. One thing I didn't like too much is that once you kiss the limiter once, it automatically goes into the next gear (yes in Manual mode).Daily 2018 Tiguan MK2 Sportline (Drag & Drop Tune, 12.9s @ 108mph)
Weekend/Track 1996 Skyline R33 GTS-t Stage 99 (Built Motor, GTX3576 Gen 2, 407rwkW) [Build Thread]
www.nhbautomotive.com.au
[QUOTE=Oz85;1277537]Did you have the traction control turned off?
My understanding is it was switched off, as soon as you put it in off road mode you get a warning that traction control is off, mine doesn't have a physical switch. but i would also assume that is what is happening.
At the end of the day it was all good fun, had a good laugh with the group of people i was with, apparently it looked pretty cool with all the lights on and jets of sand in shooting in the air - something like the fountain shows out the front of a Vegas hotel and am happy to know the limitations of the system. but i don't regret getting the car, its still a pretty good rig on the road the tech, price, performance, meant it was a no brainer when we cross shopped it with a Discovery Sport.
Side note - when we were back on the road we had to stop and clean the sand out of the inside of the rims - about a 2cm build up I'm places, which really had the wheels off balance.Last edited by craig_perth; 19-10-2018, 11:50 AM.2018 R-line Tiguan DAP
Hi DPS, this occurs with all automatic transmissions, not just VWs.Originally posted by Dose Pipe Sutututu View PostI took ours to Capertee and it was pouring rain, so I turned off traction control and spun all four wheels in the mud. One thing I didn't like too much is that once you kiss the limiter once, it automatically goes into the next gear (yes in Manual mode).
Also, if you are spinning wheels, try selecting a HIGHER gear.
There are a number of benefits of doing this. First, you have a greater control of the accelerator peddle which means your are less likely to spin the wheels so quickly and you can control the motor at a much lower RMP, again, giving you better control of your wheel slip, if it occurs.
I was being a knob on the mud on private property, tried to do donuts in the car too hahaOriginally posted by drivesafe View PostHi DPS, this occurs with all automatic transmissions, not just VWs.
I still haven't grown up.Daily 2018 Tiguan MK2 Sportline (Drag & Drop Tune, 12.9s @ 108mph)
No one really lolOriginally posted by iDiesel View PostWho says you have to grow up?
Wife is pretty good, as long as I'm doing anything silly on private property or on a race track, I get to sleep in the bedroom not the couch
In saying that, I might change the Haldex settings soon and report back. Might be doing a weekend trip soon and hitting up some offroad areas. Will report back on how much sand in the air and wheelspin I can achieveDaily 2018 Tiguan MK2 Sportline (Drag & Drop Tune, 12.9s @ 108mph)
Thread bump. Thinking of taking mine on to the beaches around South East Queensland over summer but not keen on using the standard 20 inch tyres.
Does anyone know what other VW/Audi wheels will work? Thinking I might pick up a set of older 17s and put some meatier tyres on.
Doing this to stop from buying another 4x4! Want to try the Tiggy to see if it will work for basic beach driving and basic off road before spending more $$ on another car.
Great! What size tyres are you using and do you have any pics of the wheels fitted?Originally posted by DougGlover View PostI bought some older Tiguan 16" and put AT's on - great option!
Edit: Just found your other posts with the info and pics. I wonder if all the Mk2 Tiguans have the same front brake size?
I've located a set of these wheels, could grab them to test fitment over the brakes before putting tyres on them.
