Discover pro screen internal crack?
  • #61
    Tiguan is rip off close to $65k considering is by price in premium territory, but built with poor quality parts, sourced cheap to save some ''euro'' and offset still recovering expense from DG.
    What is more worry for VAG even new upcoming Audi q3 is now almost same cheap quality materials all over similar to Tiguan built, except some nice cosmetic dashboard and front panels inserts and seats redesign, if you go under and hidden places all scream cheap ! But let we wait some more what else of this '' Proven German Quality'' will start failing apart..
    • #62
      Actually, good news is it was a bad batch, the bad news is that it was a bad batch of 5000 odd , it seems the first shipment of 10,000 units was fine, the second rushed (we did not know how well cars would sell with it) order of an additional 5000 have caused the issue.
      So there are 5000 out there that will probably get this issue, either super rushed caused it, or a disgruntled over worked workforce, I vote for the latter
      • #63
        Originally posted by dsck View Post
        On a side note. Dose anyone know how to enable the live location display (that tells you the street you are currently on) on the top left of the navigation screen? Mine is just showing the driving mode. I have another vw golf that shows current street location and the street name changes whenever you turn into a new street. Any help would be appreciated!
        Has any one been able to activate this option.
        MY18 Tiguan R Line Black-162 Highline TSI
        Drivers Assistance Package - Sunroof - Tow Bar
        Ordered July 17 Arrived December 17 Delivery Jan 18
        • #64
          The large range of build dates of the cars affected seem to make the ‘batch’ theory seem rather implausible. Unless vw only sell a few hundred tiguans- globally, per month.
          • #65
            I have chance to open play and reasarch on both generation display units in tiguan 2, including the ver 1. with knobs and ver. 2 with full glass display touch panel . The version 2 of discover pro 9.2inch it gives much niceer and more acurate color , better black level and conttas vs ver.1. However the version 2 has some serious issue with overheating ,most likely ips led panel and pcb electronics heating more and large glass like display panel atract more sun from our hot ozi sun which can get extremly hot in less than 30 min in use during sunny day. This ll will trigger inside lcd pannel ribon to pcb to fail and lose contact .The first ver. does not have this issue at all as using matte plastic display and does not atract sun and overheat . I would suggest all owners with ver.2 to run display on lowest seetings brightness ,will help lots to reduce overheat . replacment will need to have complete new version redisgned with built in behind active fan cooler or better passive radiotor cooler , or it will happen again and again to fail in hot areas like we have here in Australia
            • #66
              Originally posted by cameleon72 View Post
              I have chance to open play and reasarch on both generation display units in tiguan 2, including the ver 1. with knobs and ver. 2 with full glass display touch panel . The version 2 of discover pro 9.2inch it gives much niceer and more acurate color , better black level and conttas vs ver.1. However the version 2 has some serious issue with overheating ,most likely ips led panel and pcb electronics heating more and large glass like display panel atract more sun from our hot ozi sun which can get extremly hot in less than 30 min in use during sunny day. This ll will trigger inside lcd pannel ribon to pcb to fail and lose contact .The first ver. does not havr this issue at all. Iwould suggest all owners with ver.2 to run display on lowest seetings brightness ,will help lots to reduce overheat . replacment will need to have new version with built in behind fan cooler or better passive radiotor or it will happen again and again in hot areas like we have here in Australia
              Had the Tiguan screen replaced and works fine now.. bought a Golf R.. and no issues with that one as well with the same 9.2in display.
              Many others that also don't have an issue.
              Sent from my SM-N950F using Tapatalk
              • #67
                They can look same to you from font, however what is inside is different story If they didn't redesigned layout on the inside back PCB ad panel, maybe they just done on new batch simple solution by doing over contact hardener glue as they usually do with BGA chips which used to overheat and fail .Will try to compare if get chance those new replacement units and see if anything is different to problem versions.
                • #68
                  I am wondering if the builds are all from the same factory ?
                  • #69
                    My car (a Passat B8 2018 w/Discover Pro) has the same problem. Vertical lines on a screen.My dealer is analyzing the case.
                    • #70
                      Mine (mid-2018 build allspace) was replaced in one visit. I called and booked in with 2 weeks notice, which may have helped? 9.2” screen.
                      • #71
                        Dropped the car at Solitaire in Adelaide to have the screen/unit replaced! Picking it up tomorrow
                        MK7.5 R Wolfie
                        MK6 GTi - Sold
                        MK5 GTi - Sold
                        • #72
                          took the dealer 1.5 days but screen has been replaced and all is well.
                          MK7.5 R Wolfie
                          MK6 GTi - Sold
                          MK5 GTi - Sold
                          • #73
                            had mine replaced in the passat alltrack on thursday...
                            2018 MY18 Indium Grey VW Golf 110TSI Comfortline, DAP & Infotainment, Folding Mirrors!
                            2023 MY23 Nevada White Cupra Formentor VZx
                            2015 Carnival Yellow Honda S660
                            • #74
                              I noticed when my head unit booted this morning there was a bunch of red lines running vertically down the center of the screen. They disappeared after about half a second. Hopefully not on it's way out.
                              MY19.5 Tiguan Highline with R-Line & Sound/Vision
                              • #75
                                Probably
