G-8VXWWTRHPN Rear Dash Cam Installation - VWWatercooled Australia
  • Rear Dash Cam Installation
    Hi Peeps, just spent breakfast installing my new DOD rear dashcam. Thought I'd share a slight issue and how I solved it. Hoping this might help those of you who are undertaking installation yourself.
    The road bump was getting this cable for the rear dash cam through the rubber grommet wire loom thingee-ma-bob.
    Normally I would use my kiwi engineered zip ties for holding my bumper together but today was different. The rubber loom's white clips as seen in the pic clip out from one side.
ID:	1867295 Click image for larger version
ID:	1867296 Click image for larger version
ID:	1867297 Click image for larger version
    Bob's your uncle:
ID:	1867299 Click image for larger version
ID:	1867300 Click image for larger version
ID:	1867301 Click image for larger version
    So this took a good 30 mins including coffee and toast breaks to feed the wire from the front to the back following the drivers side roof lining, end result looks neat and tidy.
ID:	1867303 Click image for larger version
ID:	1867304 Click image for larger version
    Hope this helps someone!
    Awesome. Thanks for that. Very handy.
    Churr bro!
    Tiguan Highline 162TSI | Indium Grey | DAP | MY18
      @spacemannz haha... Churr my bro!!!
        Did the same myself over the weekend, nice and clean.
        I noticed when I removed the central plastic trim piece that it was not properly installed and the two side clips had been bent back. Luckily they hadn't snapped off, so I was able to reinstall it properly. Something to keep in mind for those of you planning to do this.
        Sent from my Nexus 6P using Tapatalk
          How did you remove the central plastic trim?
            Just pull it from the glass side. There's a small clip on each end which will pop off easily and 3 stronger clips in the middle.
            You can bend it back and "feel" where the resistance is and you can see the holes for the 3 clips in mengy's photos. The central clips are metal so they won't break.
              Awesome work mengy.. got mine just installed as well and your guide helped.
              Did you hardwire your cam? Just wondering if you did which fuse did you tap into..
              Sent from my ONEPLUS A3003 using Tapatalk
                Sorry to revive an old thread here, but I've just gone and done this exact same thing .. except that I managed to partly break the bottom right clip (surrounding the lower rubber grommet boot). It still loosely snaps into place but not as tight as I'd like. Worried about possible water ingress into the roof. Has anyone ever replaced or found a fix for these? I'll probably just add some black sealant to the grommet boot to make sure, but keen to hear if anyone else has had similar issues.
                  Well I did it slightly differently After seeing another method of doing it I did this
                  I ran a twin flex from fuse box behind glove box down trim and along floor under the door trims to rear quarter and up into left rear pillar behind taillights.after removing little pads that cover where you get to rear tail lights Earthed the neg there
                  The did the following
                  Remove top tailgate trim
                  Using a trim tool wedge top of rear pillar trim out a bit and slide a mouse down to exposed hole Attach power cable and pull it up
                  Put fingers or trim tool inside roof lining where there are 4 clips across the back
                  Pop them off becareful to only work on the clips or you can pull them off the roof liner
                  Put fingers inside tailgate and push the clip holding the flexi pipe towards centre of car and using a screwdriver on the outside lever it down gently and it will drop out Push a mouse down from the taildoor end and pull it out above roof lining.
                  No need to touch bottom end of it at all
                  Attach power cable and feed it into flexi pipe and work it through. Get it to camera.
                  pull excess down into rear pillar You can do two things now. Either attach plug end of power cable to a ciggy holder and then to the wires from the front or I simply cut the plug off and used crimped joiners. My camera is a 12v one
                  Tidy up wiring under roof lining and carefully reattach clips. refit taildoor trim
                  All done well away from curtain airbags which blow down from the roof
                    Hey guys, great tips in this thread.
                    I am having some issues in getting past the b pillar. I am pushing up in the headlining and trying to run the wire, but there is just zero room. refer to step 8 in this link . Although that is a golf tutorial, I am assuming running that wire is the same.
                    I would be hugely grateful to anyone that could share the way they ran the wire for the read cam past the b pillar
                    Many thanks!
                      Many thanks!
                      A sensible idea is NOT to run it along the roof or you will wear it if the side curtain airbag goes off. Do as I do and run it along the floor under the door trims and up into the back corner.
                      When taking the bottom of the wiggle tube just lever the inner end (under the tube) inwards a bit and you will see where it lifts out.. I use two seperate cameras so I only had to run a twinflex to the rear quarter and the original camera cable from there to the camera. If you are using body tools you should be able to get one down behind top of B pillar trim and just feed the cable in as you slide it along from one side to the other
                      What camera are u fitting. Hope fully not DOD like the OP
                        Thanks for the guide. Having done front and back hard wiring in my previous car myself I thought of giving a try with Tiguan as well. Referred the site but sadly I had lot of trouble going past the A pillar and being not able to slide off the pillar from the metal clips, I decided to go with one of my nearby autobarn fitters. Was really surprised at the very affordable price they quoted (I had all parts including fuse taps and hard wire kit with voltage controller) and was easy as. They’d done it in less than 2 hrs while I was shopping in nearby shopping centre and no dramas.
                        Happy days!
                          There is a step by step guide here for both Golfs and Tiguans which are basically identical to do
                          Dash Cam Install Tutorial – Volkswagen MK2 Tiguan – AutoInstruct
                          A Pillar Trim Removal – Volkswagen MK7 Golf – AutoInstruct
                          Dash Cam Install Tutorial – Volkswagen MK7 Golf – AutoInstruct
