You can't 'pre-load' a turbo; it's spun using exhaust exiting the engine; having enough exhaust exiting to spin the turbo requires engine revs.
The difference between economy/normal/sport mode is mostly about how the gearbox behaves and how long it holds each gear before shifting. This absolutely makes it more likely to put you in a situation where you get turbo lag. In economy mode it will shift up gears earlier (i.e. at lower revs), which puts you in your next gear at lower revs which means less exhaust which means less boost which means considerably less power.
No doubt that the DSG and it's characteristics could make this feel worse in situations others have described above where the gearbox is caught in the wrong gear.
It's probably not the answer most people want to hear (it certainly wasn't when I tried to explain it to my wife!) but you need to drive to the car you have and the conditions you're in. If you've got a turbo, expect lag and slower throttle response. If you've got a DSG, be vaguely aware that it's trying to guess your next move based on brake/throttle position and the speed you're doing.
Pretty much worst case scenario here is what was described above - coming into a roundabout with your foot off the throttle and getting into the brakes. The car will think you're pulling up to stop and is going to be changing down and getting ready to stick you in first gear to take off again, but then you hit the gas when you see a gap. You expect instant acceleration but you're at low engine revs with no boost coming from the turbo plus waiting for the gearbox to realise you want to go faster instead of slowing down. It's gonna feel pretty dead for a second or so while revs build up and the gearbox sorts itself out - that feels like the worlds slowest ever butt-clenching second when there's a guy coming into the roundabout on your right hand side and you're like a deer in headlights.
If you give the gearbox half a chance to work out what you're doing in this situation by braking early then coasting in with some light acceleration you'd probably feel a world of difference. Either that, or use the flappy paddles to manually get yourself into the right gear to have a bit of acceleration through the roundabout and then switch you back to auto when you're done.
