Originally posted by Hillbilly
View Post
OBD11 modifications
Originally posted by nova_sounds View PostI am sure than I have the newer camera as Fusion mode is not even available to adjust in OBD11 via the app. I do find this it is strange that the same model car in US and EURO seems to work?
Eg if I go up from my house via one road and turn left onto another road it changes to the old speed of 60kph If I turn right and drive a k up there and do a U turn and come back it sees the new sign and gives the current limit which is 10 above the old one. Does that on the highway as well where it used to be 70 and is now 100. Weird but thats how it is.2021 Kamiq LE 110 , Moon White, BV cameras F & B
Hello troops, just back in the VW world, having just bought a new old stock 2023 T Roc R here in Perth. Are there are any known OBD specialists here in Perth, that i can go and natter to, for things like the speed limit sign thing above? My Focus ST had that set up as std and is one thing i would like to have back on the dash asap, as well as just generally finding out what is hidden and what can be changed.Back in the VW world with a 2023 T Roc R, Silver with black roof.
The Australian spec 2023 T-Roc R comes with the 2Q camera (A5 Drivers assistance), not the 3Q version.
This camera is not capable to activate traffic sign recognition with OBD11 or VCDS.
You could remove the nag screen - Adaptation
Control unit: 5F Multimedia
Values:
hmi_initial_disclaimer:
Old value: On
New value: Off
Prevention of right side overtaking - Long coding
Control unit: 13 Adaptive Cruise Control
Values:
Overtaking_right_prevention:
Old value: activated
New value: Deactivated
and remembering your seat heating - Adaptation
Control unit: 08 Air Conditioning
Name: Retention of driver's seat heater level
Values:
Old value: active for 10 minutes
New value: active
Start/stop deactivation is not possible via coding, you need a physical bypass module.Flipper Dog
Now - T-Roc R, Audi Q5
Originally posted by Flipper Dog View PostStart/stop deactivation is not possible via coding, you need a physical bypass module.
There are however, 2 other ways of disabling it. The 1st is physical (works and I have tested/used it), simply unplug the battery voltage monitor plug from the battery and stop/start is permanently disabled.
Or put a Racingline OEM+ tune on the car ... SS is disabled by default and you have to press the button to enable it. I may have tested this 1 tooLast edited by Sharkie; 20-08-2024, 08:23 AM.Current: 2023 MY23 T-Roc R Lapiz Blue + Beats Audio + Black pack 2018 MY19 Golf R manual Lapiz Blue + DAP) 2018 MY18 Golf 110TSI (150TSI) Trendline manual White2014 Amarok TSI Red (tuned over 200kw + lots of extras) 2013 Up! manual Red 2017 Polo GTI manual Black Previous VWs and some others ...
The remove the battery monitor also stops the car from charging properly as the brain then cant see the state of charge and adjust it to suit. Has been said from way back not to do this. However others have different views on whether to do it or not. I wouldnt .2021 Kamiq LE 110 , Moon White, BV cameras F & B
