G-8VXWWTRHPN MIB 3 information - VWWatercooled Australia
MIB 3 information
  • MIB 3 information
    Looks like I am in the market for a T-Roc and I am seeking some information on the MIB 3 media system (Discover 8" MIB3 ) for my research.
    Looking over the vehicle I have noticed some differences to the Discover Pro 9.2" I have in my 7.5 Golf, can someone provide any information as the dealer is uneducated in this system.
    There appear to be no SD card slots. The old MIB2 system used an SD card for mapping data, does this mean there is no SD card for map data now? I also noticed that the mapping data is different (Australia and New Zealand only maps, not multi region). Details from other regions indicate that the mapping data is updated as required via an e-sim card, is there an e-sim in Australian spec vehicles then?
    No SD card now. Mapping is loaded internally. No e-sim, however the system can be connected to any WI-FI network for software updates.
    The maps can also be updated via the main VW site using USB thumb drive. There are some posts on the process you can look for on this forum but the MIB3 is not just simply inserting the files in and watching it load.
    The digital cockpit display appears not to allow display of maps in while it is displayed in the main screen on the dash unit. Is this correct? Is there any way of displaying maps in both as I like to have the dash display zoomed in to 150/200m and the VC displayed at 400m to give me a better prospective of the surrounding area.
    Can only have one OEM display at a time. Found coding to turn off the digital cockpit display but that is no use. Will keep researching this as there are users in Europe activating this.
    Update - Found the issue here, the Discover unit does not have the same computing power as the Discover Pro to allow the mapping images to be displayed both in the VC and main screen at the same time. The European users were using Discover Pro versions.
    Does AA/carplay navigation allow display of their maps in the dash and VW mapping in the VC at the same time?
    Yes it does
    Does the map display 3D buildings?
    No 3D buildings yet
    Is voice control, the VW one, active?
    VW voice control is not active, however on Android Auto "hey Google" works
    Has anyone activated TMC traffic info yet? Suna Australia TMC code 1024.
    No luck here. It appears traffic in via online traffic not the Suna FM code as before
    Will be fitting a dash cam which uses the 12v cigarette lighter socket to give power only when the ignition is on, noticed the only cigarette lighter socket is in front of the gear selector which is not really suitable. So looking to use the USB C sockets in the rear centre console. Are these USB C sockets powered on with the ignition or is there power for a while after shut down?
    USB C sockets (all 4 for them) power off when ignition is off. Working well with dash cam
    Flipper Dog
    Now - T-Roc R, Audi Q5
    Definitely no sd card.
    Was hoping to listen to my flacs.
    Will try a USBC flash drive to see if it works. Have read it should
    2008 Mk5 Golf GT TDI DSG
    2012 Mk6 Golf R DSG
      Nothing works. Maps cant be loaded music by air connection only
      Plenty around about its deficiencies
        i read some cases about a usb-c flash drive working for music?
        not sure how to make use of the wifi connection for music? did you find any guides?
        2012 Mk6 Golf R DSG
          You need to select media and the source - USB C sticks do work with music and video files.
          Flipper Dog
            Thanks will give it a go
            2012 Mk6 Golf R DSG
              Can the wifi in the head unit be used to play music somehow?
              2012 Mk6 Golf R DSG
                If you're using a wifi enabled app, yes it can. Example is wireless carplay - it uses wifi.
                  My Skoda picks up our home WiFi but I can't log into the home account. The only work around for this is using my phone as a,hotspot and then doing WiFi from there. Annoying but it is what it is.
                    My T-Roc is the same - can't/won't connect to home WiFi. I'm still trying to work out how to get the unit to accept or even recognise the latest map update via USB-C.
                      I had no issues getting mine connected to my home WiFi but couldn't see any benefits/new features after connecting
                      2012 Mk6 Golf R DSG
                        Wont because it cant Plenty of reading about it on various forums and all say the same. My dealer said they will update maps at each service. Because we dont have Appconnect here is the reason and Skoda are looking at what to do apparently
                          How are you guys seeing your home WiFi?
                          I have a 2021 kamiq with the admussen unit but haven't found anywhere that let's me connect the car too wifi
                          2021 Kamiq Monte Carlo
                          1.5 DSG Moon White
                            Same issue here, USB-C is reading my drive (can tell by the flashing light on the thumbdrive) but not doing anything. I have had it in the slot for a week.
                            Of interest I found this Technical Product Information on the MIB3 for software 027x (I have 0270).
                            TPI 2062880/2.
Name:	TPI MIB3-1.jpg
Name:	TPI MIB3-2.jpg
Name:	TPI MIB3-3.jpg
                            I have not approached the dealer yet as I have other things to do - like lock myself down.
                            So if any one wants to test the water, please lets us know.
                            Flipper Dog
                              @doc_777 how many usb c ports does your vehicle have ? My Skoda has two in the front and the one closest to the NSF is the one I can use to play music from a flash drive. Sorry for not being up to speed with the VW side of things.
