I have been asked by an Amarok owner if I can deactivate the 2 front cente sensors as when he engages reverse gear these two sensors pickup the bar and constantly buzz away which is very annoying
So far I have tried
1 Disconnect the front buzzer
2. Disconnect the 2 sensors
3 Disconnect the whole front wiring 12 pin loom/plug from the PDC module which is located on the A pillar passenger side.
In all 3 cases the OPS system shuts down and fails to show a diagram or buzz for the rear sensors in the RCD 510 unit when reverse is selected.
I have looked at the coding of module 10 via VCDS to see if I cannot isolate the front sensors but all I have managed to do is turn the volume down on the front buzzer from default setting of 5 to 1.
Any ideas how to disconnect the front and just have only the rear working? I know it can be done as I have seen another Amarok with a full aftermarket bullbar bumper fitted where there is a graphic display of only the rear of the ute and only the reverse sensors work.
Ps has anyone managed to get the rain closing of the windows to work on the Amarok? managed to get the cornering of the fog lights to work
So far I have tried
