The dealer gave me a called to let me know the the new work Amarok should be arriving at the end of May. Unfortunately only 17" wheeled Trendlines available, I only wnated the standard 16" wheels.
Hopefully at the Dealers end of May
unfortunately we are all having to put up with that. the non-optional option... Must say though, I am happy with my 17's. tyre choice for them is still adequate.www.wolf4x4.com.au - Australian Seikel Distributors.
Zenec Headunits for VW/Skoda - http://www.wolf4x4.com.au/zenec-nc-2011d/
www.ausamarok.com.au
Exactly why I am happy with the 17's!!Originally posted by fouros View Postat least with the 17's you get the fender flares
The factory tyres are 245/65/17 Bridgestone Dueler H/P
265/70/17 will fit no issues at all.
285/70/17 will require a lift, cutting a bit of the inner gaurd and different offset rimswww.wolf4x4.com.au - Australian Seikel Distributors.
I have nothing "on file", but if you look at the base modell here:Originally posted by dbrad View PostChristian,
do you a webpage or photos of the difference in the wheel arches as the brochure pics must all be wide arches as I can see the difference.
http://www.goauto.com.au/mellor/mell...tion_LARGE.jpg?
you get an idea. Probably a 1/3 of the width if extended arches are fitted?
On a positive note/thought, you should be able to get the arches through "parts", so if you want the 16" for better choice of tyres or after market rims, just get a T/Line with normal tyres & arches and add the other stuff later...Christian Sieg
