Hey all, I'm after some despite help locating the ECU coolant temp sensor on a 2018 Amarok with 3.0L V6 engine. The manual that I have is saying it is under the intake manifold and behind the oil filter housing, but it's not there...
I've just finished resealing everything in the valley after a major oil leak developed, so engine oil cooler, water pump, thermostat, a few plastic pipes, hoses and a heap of orings/seals all got replaced. There was no fault before I stripped it but now I'm stuck with a fault code and the ECU thinking the coolant temp is 150' C at cold start.
I have nearly pulled all my hair out and almost stripped this thing back to where it was to replace/ reseal everything but still can't find the ECU temp sensor...
