So I started up my car for the first time in about a week after installing a new reverse camera + head unit and my coil light started flashing on my drive and the car went into limp. As it was late I took it home and left it over night, when I started it the next day I had the same flashing light But I also had a solid yellow engine light. manual says this is a catalytic converter fault. Scanner is only throwing 1 code which is P261A something with aux pump B which goes to the EGR I believe.
Is it likely this is just a clogged EGR valve or something worse? I've booked it in for a service in a few days
