2012 amarok ABS/ESP issues
  • 2012 amarok ABS/ESP issues
    Hi all,
    Anyone encountered the issue on a 2012 amarok 4X4 manual.
    ABS/traction light stays on.
    I’ve attached a photo of the codes that are not going away.
    -I have reseated the electrical plug on the ABS module. No success with DTC erasure.
    -have not checked each wheel speed sensor yet.
    -have not checked ABS/traction system fuses yet.
    It is saying electrical fault within ABS hydraulic unit[emoji3544]
    I’m thinking internal electrical failure of a system or sensor within the ABS module.
    Hoping to avoid the $650 replacement of the unit and coding. [emoji28]
    Get one from a wrecker. Make sure you take a copy of your current ABS long coding string as the VIN is encoded into it as well as a bunch of settings.
      So it does have to be coded by an auto electrician with the Scantool?
        Yes with suitable diagnostics tools like vcds, obd11 etc
        Sent from my SM-G960F using Tapatalk
          Do you know of any workshops who overhaul these ABS units?
