Hi All,
I recently bought a used 2011 Amarok with engine code CDCA and 145,000km on the clock. After a bit of research I wanted to check that it had the newer lower timing belt cover installed. It didn't so I went about replacing the old one this weekend.
Replacement went well but I did notice that the timing belt, which should have about ~30k km on it if the service record is to be believed, was possibly not at the correct tension. The tensioner indictor arrow is to the left of the marks you use when tensioning a new belt (see below).
My question is, is it supposed to be like that after use or should I be applying some more tension to the belt?
https://imgur.com/a/R70MZkP
