I think my car has developed an AWD/DSG failure.
I tried to take off from stationary enthusiastically and the front wheels kept hopping and not able to put power down. The 1st to 2nd gear was also very slow (like manual gear box shifting) with a big loss of acceleration (my body jerked forwards) before 2nd gear is engaged. The 2nd to 3rd shift is much faster (normal speed). No error code was triggered. Car was in normal mode, DSG in D, and I just stepped 100% on the accelerator. The wheel hops occur even if I just step say 70-80% accelerator as well.
See video VW Golf R Mk 7 wheel hop - YouTube
Then I tried launch control - car in race mode, DSG in S, hold stability contorl to turn it off, hold down brake, step on accelerator 100%, car hold rev at 3500rpm, lift off brake. The car slipped the front wheels, speedo showed 90kph, then the car finally cut power and wheels gripped, with the speedo dropping back to real road speed. I did a VCDS scan afterwards and the below error was triggered at the time of this video.
1 Fault Found:
16670 - All-Wheel Drive
C1113 07 [008] - Mechanical Failure
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 1
Fault Frequency: 1
Reset counter: 121
See Video VW Golf R Mk 7 launch control wheel slip - YouTube
Can someone please tell me that a Golf R is not meant to wheel hop, and launch control is not meant to slip the wheels (even though stability control is off)?
1 Fault Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 121
