Hi. I was wondering if someone could help me please. I have recently (within the last 2 hours) swapped the headlights in my MK7 June 2015 Golf GTD for a pair of brand new Golf Mk7 R headlights. The only difference I can see between my original lights and these new ones is that the Golf R lights have LED indicators and the extra "U shaped" LED DRL. My original lights were the type with xenon low and high beams, 1 x U shaped DRL and cornering lights.
The fitment of the Golf R headlights wasn't too much of a pain at all really but now I have them fitted it appears I have lost my main (high) beam function and I have a warning message on the dash regarding a fault with the cornering lighting. The surprise to me was that the LED indicators didn't cause any lamp out warnings on the dash even though my original indicators were regular incandescent lamps?
Is there an easy fix to this does anyone know (DV52?). I would like to thank DV52 for the brilliant document he produced on the lighting control and function settings, it has proved invaluable to me but I can't see how to solve this little predicament I'm in!
I'm nervous that my headlights maybe stuck in high beam and not that I've lost it altogether.
My original headlights had 3 control modules bolted to the underside of each headlight, the new Golf R headlights had 4 modules. I assumed that the extra module on each headlight was for controlling the extra DRL.
I live in the UK and got the Golf R headlights off a UK EBay seller who stipulated they were suitable only for UK Righthand drive vehicles.
I'm loving the double "U" DRL's and the LED indicators but these other problems may force me to change back to my original lights if I can't find a solution. I can't think why I should lose a main (high) beam function when that particular aspect of the headlights is common to both pairs of headlights?
One difference I observed between the two sets is that my original headlights had 12 pins where the wiring loom plug attaches (with pin 4 - when counting from left to right) missing and the Golf R headlights had only 11 pins (also with the same pin 4 missing).
I have VCDS so I'm going to go and see if I can work anything out using DV52's document as a reference. I'm hoping that telling the central electronics module that the car doesn't have cornering lights will solve the cornering light warning message issue. As for the loss of high beam (or permanent high beam - I'm still not sure which) I have absolutely no idea at all!).
Sorry for rambling on, I just wanted to try and get as much info over as possible to aid in potential diagnosis and hopefully solution!
Thank you.
Jon.
Thank you.
Jon.
