Originally posted by rosslm
View Post
Golf R Metallic Ringing Noise
Originally posted by rosslm View PostHow long have you had the rattling around 2000 rpm, sounds suspiciously like the fuel line buzz (also sounds a bit metallic like a heat shield) very noticeable negotiating roundabouts and corners in S mode as the gears changed down increasing revs into the 2000-3000 rpm range my previous 7R had no fuel line buzz but I could faintly here the turbo bell ring at 3000 rpm but this never was annoying unlike the fuel line buzz.
My dealer confirmed with a test drive that it’s the turbo rather than the fuel line. As others have said, it’s a bell ringing sound but I do have a buzzing that probably is the fuel line but I’ve never been able to put my finger on it (sounds like it’s coming from the back of the car).
Sent from my iPhone using Tapatalk ProMY08 Mk5 GT Sport - sold
Just picked up my brand new Mk 7.5 Golf R a week ago.
Wearing it in slowly. I quite the car, but hate the rattling. Makes the car feel cheap and tacky like a '94 Hyundai.
I have rattles from
1. Both driver and passenger door trims caused by road vibrations and music - stops with application of pressure
2. Rearview mirror housing rattle caused by Soundaktor and music.
3. Soundaktor rattle
4. Dreaded 3K RPM metallic ringing noise.
really disappointing for a $57,000 car.
I'm not so concerned about the first 3, as there are solutions for these and are being fixed under warranty.
Nothing (yet) can be done about the metallic ringing noise.
Originally posted by CaptianAndg View PostJust picked up my brand new Mk 7.5 Golf R a week ago.
I have rattles from
I have this bell ringing noise to and it does my head in! Thankfully its intermittent and music easily drowns it out
Sounds like its coming from the front right wheel, usually at lower speeds when just coasting along not so much under acceleration, haven't found any regular triggers for it.. usually occurs after extended driving.2016 Golf R, APR Stage 1
2010 Polo GTI 9n3, 4 Program APR Tune, PD160, White line front and rear sway bar
I've got both rattles in the door (same as my MY14 103TSI wagon) that vanish after pressure is applied outward to the door, plus the ringing of bells from the engine as described earlier. MY18 R wagon and it's approaching 1000km, so still a baby. First noticed today.
Neither of these issues were present in the vehicle I test drove (which had <100km on the clock).
Has anyone had any luck getting these attended to?
Originally posted by zardoz View PostHas anyone had any luck getting these attended to?
Originally posted by Primordial View PostOk guys, well I have good news and bad news.
I'm pretty sure I've found the source of the rattle. The bad news - I don't think it's going to be easy to fix, without removing the dump pipe to fix, or by replacing it obviously..
The rattling sound sounds suspiciously like the metal shroud/cage around the downpipe flex joint. Unfortunately this will be pretty difficult to access without removing the downpipe. Likely why VW wont release a 'fix' for it, because its at least 3-4 hours of work just to get the downpipe out!
I made a quick video to explain:
Verify to Continue
All good bud, happy to help
It’s a long shot but would MY20 Tiguan Allspace or Tiguan have the same DP? I’ve noticed this muffled grating noise from Day 1 and it’s been 2 weeks since picking up the car from dealership now and only getting louder. It happens on accelerating through D1-D3 up to around 2000rpm and after that it fades away due to engine noise etc. it’s not present at idle or revving at idle. I also own an MK6 GTI which had the clip installed on wastegate actuator in 2011 so I’m familiar with the noise and it’s not the same one.
I’ve been researching on this forum and international forums before heading into the dealer and after watching this video it’s very convincing that it sounds exactly like that noise from the mesh join. Another poster here mentioned sound of cabasa and I had a listen to the link and I think it’s that type of grating metallic mesh noise.
Other forum members in Tiguan forum advised it might be loose fuel rail which I’ll also look into but this seems quite likely as well. I had a look underneath to see if heat shields were touching propshaft towards the rear diff but there is about a finger width in there and a bit less than that above the cat converter. Looking from some distance around DP area it did look a bit cramped up in that area with heat shields etc.MY20 Tiguan Allspace Black - R-Line, S&V, Pano roof
MY11 MK6 GTI Black - Leather, Sunroof etc.
MY17 MK7 Golf 92 TSI
MY18 Mazda CX-9 Touring AWD (For sale)
