Good to know, thanks. I'll start with trying the heat proof wrap I think!
Golf R Metallic Ringing Noise
I'm waiting for another Guinea pig to test/confirm the DP fix theory (c'mon guys!).
I took my mine to a local exhaust place recently, put it on an hoist and tried without success to locate the rattle in the visible part of the DP.
I'm worried that it's somewhere closer to the turbo/waste gate (as per another theory mentioned previously). My concern is: I spend a bucket on a DP (and intake and tune) and am still left with the lovely metallic/metal ball in a glass jar rattle (nb I wouldn't otherwise feel the need to mod my R). Just wondering should I cut my losses and sell up as if entirely ruins the driving experience for me
Originally posted by andrew7 View PostI'm waiting for another Guinea pig to test/confirm the DP fix theory (c'mon guys!).
I'm worried that it's somewhere closer to the turbo/waste gate (as per another theory mentioned previously). My concern is: I spend a bucket on a DP (and intake and tune) and am still left with the lovely metallic/metal ball in a glass jar rattle (nb I wouldn't otherwise feel the need to mod my R). Just wondering should I cut my losses and sell up as if entirely ruins the driving experience for meLast edited by Primordial; 21-01-2016, 02:13 PM.
Originally posted by Primordial View PostCould you reach the flex joint of the downpipe when you had it up on the hoist? Because I'm certain that's where the sound is coming from (did you see the Vimeo video posted earlier in this thread?). Would be handy to know if the flex joint is accessible without removing the DP. If it is, you could wrap it without having to remove the downpipe (thus, it'll be quite a cheap fix!)
Originally posted by andrew7 View PostJon, the flex joint and heat shroud was just visible, but would be very hard to wrap without removing the DP. The mechanic and I took turns under the car when it was up on the hoist with the other revving the car/putting into gear briefly and idling it. It wasn't clear that the flex joint/heat shroud is the source of the rattle, at least from under the car. It was really hard to pinpoint where it was coming from which was frustrating. I'm going to see if I can put up with it for awhile longer before deciding whether to bite the bullet with JB1 and DP (just wish there was someone who could install the JP1 in Melbourne).
As DKC mentioned, it's pretty straight forward to install. You just need the right screw bit to remove the plastic under-tray (I believe it's a Torx bit).
Originally posted by lu9999 View PostI had the same sound on my 500km MY16 R as well, it is noticeable around 2000-2200rpm when the engine sound is not come up, it is bit annoy for the sound but not a "problem" need to be concern?
As an additional update I had vw here in Adelaide checking this noise out. They admitted it existed and compared it to other cars including a gti (I have an my16R) which all had the noise. They finally palmed me off with the usual induction noise excuse so no happy ending. They did say they would log it with vw though. Everyone needs to get into their local service centre and complain!!
I sent mine back in for service to see if they could identify the problem any more. I went for a drive with the technician and he could hear the noise, and said he recognised it from other Golf Rs.
The report I got back after service states that there is a TPI from VW on the issue saying "Found noise to be unfavorable flow conditions in the turbocharger which leads to a pinking noise. This noise is construction related and normal. There is no parts dam..." (not sure if it was cut off at the end)
If the noise is there all the time (which it is) then it means those unfavorable conditions are there all the time too. I would say that constitutes a defect.
Originally posted by TFAD View PostI sent mine back in for service to see if they could identify the problem any more. I went for a drive with the technician and he could hear the noise, and said he recognised it from other Golf Rs.
Question - do the gti guys have the rattle?
My GTI had a noise consistent with this thread, mainly noticeable on cold start and initial low revs.
