Would anyone know when the ACC slows the car down, does the brake lights go on?
ACC and brake lights
Hi Hillbilly, shall test it out with a friend.
Does it the light goes on when the ACC slows the vehicle down with engine braking or it doesn't know and turns on the brake light when ever the car slows down? because that would really annoy the car behind when you.GOLF V GTI DSG Silver : On loan to parent until wife thinks I am a responsible driver
GOLF VI 118TSi DSG Silver Leaf
GOLF VII 110TSi DSG White
GOLF VII GTI pp : on negotiation
You would be correct I misread what he was asking. If you just lift your foot when normal driving the brake lights dont come on so dont when on ACC. However if a car cuts in front of you and ACC has to brake THEN they come on.Originally posted by agentthumb View PostI believe the lights only come on on brake application by ACC.
Seems logical. normally I find that unless that happens it is very smooth and just stops you from driving into someone by slowing you down gradually as you get closer.
However in QLD the closest setting is not close enough for the tailgaters here. LOL2021 Kamiq LE 110 , Moon White, BV cameras F & B
agentthumb & Hillibilly: thank you for your inputs. It make sense that the brake lights only come one when ACC applies the brake. Yes, there are alot of tailgaters here in Brisbane, I tense to ignore them and drop my speed back to the speed limit.
On a side note, are you meant to apply the brake when the car comes to a complete stop or just let ACC stops then restart the car? I've tried both. The ACC won't restart the car if i apply the brake. I guess like the normal cruise control, applying the brake will cancel it.GOLF V GTI DSG Silver : On loan to parent until wife thinks I am a responsible driver
Nice, thanks for the tip and sorry for the late reply. Have been busy with work. Happy new year everyone.Originally posted by agentthumb View PostI let ACC come to a stop. When you are ready to go, press "res" on the steering wheel or tap the accelerator and ACC will take off.
Sent from my iPhone using TapatalkGOLF V GTI DSG Silver : On loan to parent until wife thinks I am a responsible driver
I had the same question, So while driving at night I tested my ACC to see when the break light reflected on the rear window. I found the break light does come on but not every time the car felt to be slowing it was only on when the car was coming to a stop following a car or a steep downhill decent.
On mine the BRAKE light comes on and sometimes on a descent.Originally posted by GolfVII View PostI had the same question, So while driving at night I tested my ACC to see when the break light reflected on the rear window. I found the break light does come on but not every time the car felt to be slowing it was only on when the car was coming to a stop following a car or a steep downhill decent.2021 Kamiq LE 110 , Moon White, BV cameras F & B
