Originally posted by pologti18t
View Post
Back to the ADR though, there is nothing that says the speedo *has* to be electronic - hence probably the very wide tolerance allowed not withstanding the fact the speedo can't under read... The ADR even specifies a temperature for testing (23ºC IIRC) which would affect mechanical speedos (with drag cups, hair springs etc.) more than electronic ones.. Practically every car that has an engine management computer needs a digital speed input from somewhere so it makes sense that speedos be digital too..
Personally, the only car I ever came across that was fuel injected with a mechanical speedo was the 3.0L VL Commodore (the one with the Nissan engine)... I'm sure there are others but when you consider the 5.0L V8 at the time was still carby fed you can kinda see why...
- Anthony
