Magnatec Dampers -v- Standard Twin Tube Dampers
Volkswagen has done a sterling job of adding extra chassis rigidity in the new MQB Golf 7 platform. This allows Volkswagen the ability to really firm up the suspension on the Golf 7 R, with less effect to chassis integrity, twisting or torquing & with less effect on wheel/tyre integrity under cornering loads. The improvement in the Golf 7 range is tangible.
I believe that Volkswagen could only go so far with the earlier MK6 Golf platform in terms of a harder core sport suspension set-up due to potential for chassis flex (i.e. Ray adding 4mm and 6mm irrigation tubing inside his door frame rubbers).
Fitting a set of KW/H&R/Bilstein/Koni Sports coilovers and set of aftermarket sway bars will stiffen up the suspension tune on the MK6 Golf chassis, but not the overall suspension integrity in relation to the chassis stiffness that the new Golf 7 R MQB chassis has built into it, therefore never creating that tuff’as’nails chassis feeling of the Golf 7 range.
In other words, the stiffer chassis allows for more sporting suspension tune in the new Golf 7 R. Volkswagen had the ability to really up the ante in sporty suspension tune to compete with the harder core type of vehicles, WRX STI and EVO. It appears that Subaru has done a similar thing with the new STI from early reports re: aggressive suspension tune that enables the tyres to be worked harder with greater chassis integrity, faster turn-in into corners and less body roll & lean.
The issue I have with the Golf 7 R is that the dampers are stiffer, but lose a bit of premium feeling in the process. You can tell that that the stiffer dampers in the Golf 7 R are built to a price. This seems to be masked to a higher degree in the softer & lighter Golf GTI.
Additionally, the magnetic dampers in the Audi offer an alternative to the standard Volkswagen dampers (I imagine standard oil Boge-Sachs dampers). Just look at what Volvo did with the Polster S60 on Ohlins dampers, firm and relatively comfortable. Renault Sport have also done a reasonable job re: quality of damping hardware in the Megane RS265. This may be something to consider when shopping a Golf R –v- Audi S3 and may be a reason why more grown-ups are opting for the Audi.
While on this topic: The extra sporty & firm chassis tune of the Golf 7 R in contrast with the 7 GTI and MK6 R, the 7 R big wheel/tyre combo, turbine whistling aftermarket noises very audible within the cabin, and a bit of exhaust noise and drone in addition to suspension noise … I’m thinking that the Golf R is the perfect competitor to the new Subaru WRX STI … both are now comparable on price.
The next review I conduct may be for WJ’s old-chook: Holden Calais/Caprice –v- Audi A3 Sedan (pref. diesel).
Here’s another video review of the Golf R, which disagrees with WJ on ride comfort re: Golf 7 R. If only the tester drove out of that car park?
WJ
WJ
