Post removed
Mk 7 Golf R. 7.5 LED headlamp upgrade
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2 maximize 16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2 maximize 16
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2 maximize 16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2 0 16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2 0 16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2 0 16
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2 0 16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2 00 16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2 00 16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2 not active 16
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2 Always 16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2 not active 16
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2 not active 16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2 not active 16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2 not active 16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2 not active 16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2 not active 16
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2 not active 16
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2 not active 16
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30 maximize 16
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30 maximize 16
POST KEPT TO REMEMBER INCORRECT CHANNELS CHANGEDLast edited by Protec; Today, 05:19 PM.
Protec: Hmm........ NO!! As I said in my previous reply
Originally posted by DV52 View PostIn terms of BCM coding and based on my table conclusions, the Leuchte-sets in the BCM as factory coded for the High/Low beam lamps should be OK for the purpose of the 8IT fittings. However, the Leuchte-sets for the remaining old 8IM lamps should be disabled in the BCM because the 8IT fittings do not use these leuchte-sets.- Leuchte6ABL LC5 left-side low-beam
- Leuchte7ABL RB1 right-side low-beam
- Leuchte10SHUTTER LB23 left-side high-beam
- Leuchte11SHUTTER RB22 right-side high-beam
And once more, the ONLY (caps for emphasis and clarity) Leuchte-sets that need to be disabled are (:- Leuchte2SL VLB10
- Leuchte3SL VRB21
- Leuchte4TFL LB4
- Leuchte5 TFL RB32
- Leuchte8FL LB39
- Leuchte9FL RB2
- Leuchte 0 BLK VL B36
- Leuchte1BLK VRB20
In regard to posting-up admaps on this forum - Your previous BCM part-admaps are formatted inappropriately!! A BCM admap is a large relational database with an adaptation-channel count in the thousands!
A BCM admap is extremely complex and it needs to be formatted correctly if you expect others to analyze the information!
So - first set-up the VCDS dialogue-box as below:
The set-up above produces a BCM admap file with a .CSV format - a file with this extension is much easier to parse into high-level apps like MS Excel/Access.
The advantage of .CSV files is that they accommodate relational databases much better - this means that functions like "search" and SQL queries are easier!
So, after the .CSV admap file has been generated - upload the COMPLETE file onto a third-party hosting site (there's lots on the electric internet) and include a URL link into your next post.
Finally, this thread has become very unwieldy and confusing - it urgently needs to be cleaned-up!!
Dumping part-admap contents into multiple posts is unhelpful! I suggest that you remove the many part-admap posts that you have previously created - they are too confusing and they are of no value in understanding this problem!! All that's needed is a simple URL link to the BCM admap file (with a .CSV extension) as I explained above.
I also suggest that you do the same with the part- SCAN reports. You should be able to attach the COMPLETE scan file (with a .TXT extension) to your earlier forum post as a simple forum attachment.
Don
PS: a couple of additional comments regarding your assertions about the BCM:
You said: "Computer logic I assume as you would expect it would go from 1 > 19 however it actually puts the number 2 after 19."
VCDS is unique in that it orders adaptation channels according to the 2 x leading TAG numbers (no other diagnostic device uses TAG numbers). So for example, the channel order in a BCM admap for the Leuchte-set for the left front turn-signal lamp is as follows:
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0
Notice that the channels are ordered first by the leading "Parent" TAG # ENG116936 and then by the "Child" TAG#. This doesn't change anything, it is purely a list position thing!!
You said: "My car has 646 Leuchte channels." This cannot be possible in a "normal" BCM!! As I said in my earlier reply to your thread:
Originally posted by DV52 View PostA Leuchte-set is made-up of a group of 19 x adaptation channels................... There are 35 x Leuchte-sets in the BCM - so there are 35 x 19 = 665 Leuchte channels in the BCM.
Last edited by DV52; Today, 12:33 PM.Please don't PM to ask questions about coding, or vehicle repairs. The better place to deal with these matters is in the forum proper. That way you get the benefit of the wider expertise of other forum members! Thank you.
