Originally posted by ak77
View Post
In requesting the BCM admap, I was hopeful that I could spot another reason for this problem. But despite the mighty strange admap that you have provided - none of the weirdness dispels the fact that the BCM is operating the fog-light function correctly at the connectors.
So I'm not sure how familiar you are with electrical theory - but this situation seems to be one where the BCM is supplying the correct voltage, but no electrical current is flowing out of the BCM. If I was looking at this problem anew, I would suspect that the fault was due to incorrectly polarized LEDs. As I assume you already know, LED is short for Light-Emitting-Diode and diodes conduct ONLY if the +ve voltage is connected to the anode lead. If the +ve voltage is instead connected to the diode's cathode lead, the LED won't conduct resulting in "no electrical current flowing"
But, I assume that when you hook-up the temporary battery supply to confirm that the fog-light lamps actually work. you connect the +ve/-ve battery leads to the connector pins with the same pin polarity as the the way that the BCM supplies power.
So, because we have ruled-out coding and reverse-polarity as possible causes for this problem and because you have assured me that the LEDs work properly - I'm scratching my head!!
Don
