VW Golf 7 2014 year lights problem
  • VW Golf 7 2014 year lights problem
    Hello guys,
    I have VW Golf 7 2.0tdi with bi-xenon headlights and auto function on my lever.
    I want to know, is there any option, when the car is running on sunny day and my DRL's are ON, rear lights are ON too, but i want to be only from DRL's ON ?
    When its sunny day DRL's front/rear and interior lights are ON. I want on sunny day DRL's to be ON only on front and when the night come, to switch the lights in interior, back lights and headlights ON.
    As I see the other cars by the day, work only front DRL's
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 20.4.1.0
    Data version: 20200331 DS317.0
    www.Ross-Tech.com
    VIN: WVWZZZAUZFP556075 License Plate:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F
    VIN: WVWZZZAUZFP556075 Mileage: 240930km-149706miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    5F-Information Electr. -- Status: OK 0000
    Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
    Part No SW: 5Q0 937 086 AA HW: 5Q0 937 086 AA
    Component: BCM PQ37BOSCH 028 0106
    Revision: -------- Serial number: 86580410140583
    Coding: 00001A42C24102FB4BE44000000C0708100000000000000000 0000000000
    Shop #: WSC 00078 790 12345
    ASAM Dataset: EV_BodyContrModul1UDSBosc 013004
    ROD: EV_BCMBOSCH_013.rod
    VCID: 79F958E3F8D95B4E4C-802C
    Control Unit For Wiper Motor:
    Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
    Component: WWS 140905 043 0551
    Serial number: 140920203128
    Coding: 0E4DDD
    Rain Light Recognition Sensor:
    Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB
    Component: RLHS 037 0059
    Serial number: S5Y14M10D10H15M24S43
    Coding: 00A8DD
    Relative Air Humidity Interior Sender:
    No fault code found.
    Address 55: Headlight Range (J745) Labels:| 7P6-907-357.clb
    Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
    Component: AFS-ECU H07 0090
    Revision: -------- Serial number: --------------
    Coding: 069800000B000200
    Shop #: WSC 00028 028 00067
    ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120
    ROD: EV_HeadlRegulVWAFSMQB.rod
    VCID: 408FF507DB83CA864B-8014
    Left Headlamp Power Output Stage:
    Subsystem 1 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
    Component: LeiMo links H01 0002
    Coding: 2E0000
    Right Headlamp Power Output Stage:
    Subsystem 2 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
    Component: LeiMo rechts H01 0002
    Coding: 2E0000
    Thank you.
    Golf 7 2.0 TDI 6DSG Highline
    @ConfusedGolf: Based entirely on your description (and, if I understand your words correctly), I'm guessing that your car has "Scandinavian DRLs" enabled.
    Try this:
    [09] Cent. Elect.
    Security Code: 31347
    Adaptation channel: Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht > not active
    Don
      Why worry at least the cars behind can see you which is the whole idea of having them.
      We in Australia enable them because on wet days idiot drivers think that having front DRl's on renders them visible.
      They can see but who can see them from behind.
      In some European countries they are compulsory so I would check before disabling them
      Is one of the most sensible things you can have and first mod I made to my cars. To turn them off is Foolish in my eyes
        Hey Don :
        This this is enabled, because when I disable it, all lights are off during the day, include the front drl's.
        Hillbilly :
        I drive in Europe and having all lights during the day isn't ok. That's why I want to have the lights like from the factory, but someone is messed with the codding maybe ..
          Originally posted by ConfusedGolf View Post
          Hey Don :
          Hillbilly :
          Is there a law against it or just your personal preference. I have never seen anywhere say you CANT do it and nowadays a lot of countries mandate DRL's and make them safety devices which are illegal to turn off.
          I would sooner be seen and called a numpty than be hit up the arse and proved to be one for the opposite reason
          Probably some one sensible changed them
