Is there any way to find out what version of firmware / software my golf r DSG and ecu is running . It has always been serviced by private garages prior to my ownership and I’m curious to find out if there is a newer / updated software firmware available .
Mk7 golf r
Well what have you got so they can tell if there is a later one??????Originally posted by godzilla View PostOkay done . Any one work for vw and can tell me if there is a revision / updated software firmware available2021 Kamiq LE 110 , Moon White, BV cameras F & B
It isn’t as clean down shifting from 4 to 3rd and sometimes into 2nd in d mode . Sport and manual mode it fine. Tuner friend said there might have been a software update to correct it . ( had the car a year and half and had always done it , never gotten worse , stayed the same )
If you have a reasonable relationship with your local VW dealer, I'd suggest you go to them and ask them to check if there is a new version of the software. Most likely they will do it and update for you (likely at a cost) if you explain the symptoms. Try Austral VW in Breakfast Creek.Current: 2023 MY23 T-Roc R Lapiz Blue + Beats Audio + Black pack 2018 MY19 Golf R manual Lapiz Blue + DAP) 2014 Amarok TSI Red (tuned over 200kw + lots of extras) 2013 Up! manual Red 2017 Polo GTI manual Black Previous VWs and some others ...
