Originally posted by VR28LT
View Post
Why is 504 / 507 oil so readily available when it should not be used here?
Originally posted by kakao View PostCan someone please translate the meaning of 502 / 505 suitable for 2020 Golf TSI.
What is the equivalent of 502 / 505 that one can buy in AU, from brands such as Penrite, Valvoline, etc, thanks.
Or just use Penrite Enviro+ 504/507 My TSI Polo has been running on it for 10 years without problems.
A bit much overthinking in this threadLast edited by Guest001; 06-10-2020, 05:24 PM.2021 Kamiq LE 110 , Moon White, BV cameras F & B
Originally posted by Hillbilly View PostA bit much overthinking in this threadcarandimage The place where Off-Topic is On-Topic
Originally posted by kakao View PostIts also interesting there is no mention of the oil capacity in the Manual of my TSI 2020..?!?
How many liters do we need when changing oil (new filter, of course) ...?!??
A Tiguan 162 takes 5.7L Its the Golf GTI engine
A quick Google revealed this Unofficial MK7 Oil Change Guide | TDIClub Forums
and this Easy isnt it if you can be bothered Volkswagen Golf VII engine oil capacity – OilchangeLast edited by Guest001; 07-10-2020, 10:12 PM.2021 Kamiq LE 110 , Moon White, BV cameras F & B
Originally posted by kakao View Post[ATTACH=CONFIG]51101[/ATTACH]
I think I'll go with this one for my Golf TSI 110Kw 2020 ..
It is VW 502 00/505 00
I use 502.00 in my old dunger occasionally because It's often on sale for $15 if you know where to look but my car is 10 years out of warranty but in a 2020 model still under warranty? Why would you risk it? VW502.00 is a 1990s spec. lolcarandimage The place where Off-Topic is On-Topic
Originally posted by brad View PostYet Castrol doesn't even mention this oil as even the 2nd choice and nor does Penrite. What does your owners manual say?
Oil companies generally offer just two main types of oil. Low and high SAPS. They are not "older" and "newer" and certainly not "minimum" and "better". High SAPS is VW 502, MB 229.5, BMW LL-01 and generally the one product covers all of these for any given viscosity. Low SAPS is VW 504, MB229.51, BMW LL-04 and again generally one product covers all of these for any given viscosity. They are all current oil specs. Note BMW and Merc clearly say do not use their low SAPS oil in petrol engines in Australia. Volkswagen do as well but they are more vague about the wording of it.
The person asking not only has the factory fill engine bay sticker say to use 502 but also like all the others, the owner's manual too.Last edited by bradsm87; 08-10-2020, 09:18 PM.
You would think a person who supposedly knows so much wouldnt have to post 5 pages to know what oil to put in a vehicle when a read of the manual would tell you.
Ive owned 37 cars latterly 3 VW (happily running on 504/507 for last 10 years) in last 64 years and not had any trouble lubricating themLast edited by Guest001; 08-10-2020, 11:20 PM.2021 Kamiq LE 110 , Moon White, BV cameras F & B
Originally posted by Hillbilly View PostYou would think a person who supposedly knows so much wouldnt have to post 5 pages to know what oil to put in a vehicle when a read of the manual would tell you.
I have already responded to you saying the same thing before. I never said running one oil or the other will cause some sort of chaotic "problem" so your repeating of what you've used without "problems" is not relative to this thread. It is obvious that you have nothing constructive to say so please keep this thread for discussion relevant to the topic which is discussion surrounding the owners manual stating not to use 504/507 in countries without EN 228 compliant fuel. Thanks.
Originally posted by bradsm87 View PostThe person asking not only has the factory fill engine bay sticker say to use 502 but also like all the others, the owner's manual too.
You get your car serviced at the dealer. They use 504.00/507.00
You look up any mainstream lubrication database: 504/507 is their "Best Choice" oil.
You do UOA at 15,000km on 504/507 and there are no red flags for raised acid levels (or any other form of oil degradation unless the engine is crapping itself due to poor VW parts).
I actually think you are misreading a very badly designed table.
BTW: You still haven't stated what VW Tech said when you contacted them.
Here's the thing. Even if the dealers are wrong in what they think you should pour into the engine, if the dealers think that 504/507 is the correct oil for a vehicle and there is a warranty issue, you then have to go through the process of re-educating them while fighting a warranty claim. Given how many engine failures VWs get through poor design and short R&D time frames do you really want to have to add that extra layer of heartache when you are trying to get piston (or engine) replaced or a new head because the timing chain tensioner pooped its pants?
Hillbilly and I have a long history of disagreeing with each other but in this case I'm in his camp.carandimage The place where Off-Topic is On-Topic
