I have a 2014 GTI, purchased new, which I’ve had a TON of issues over the years, all covered under warranty and goodwill.
Some of the significant issues I had with the vehicle 3-4 years ago were with the cooling system. The water pump failed several times resulting in the vehicle overheating, and on one occasion the sensors also failed and the vehicle was driven for considerable distance with no coolant.
Today I noticed oil in the garage where I park my car - I’m the only one that parks there and it looks like it’s been leaking for some time as there’s both dry and fresh oil.
I’d like to know if an oil leak could potentially be attributed back to the faulty water pump, and the previous issues with the engine overheating? I voiced my concern with Volkswagen at the time I was having these issues as I was very concerned that the engine overheating on several occasions and to the to the degree it did that it might have damaged the head gasket? And in turn resulted in an oil leak?
My mechanical knowledge is pretty limited so any info would be really appreciated so I can work out the best way to tackle this issue with the dealer.
Thanks!
Thanks!
