Turning the indicator light off that's inside mirror
  • Turning the indicator light off that's inside mirror
    Is there a way to turn the small indicator light that the driver sees in the mirror? I don't see the need for it and as it's the same colour as the blind spot detection light it detracts from that.
    I can obviously cover it up or paint it, but was hoping there was a software tweak or setting change.. I can't seem to locate that however.
    The mirror LED including the bit that sits in the inside cut-out is a single assembly, there’s no separate lighting channel that can be controlled from the BCM.
      Makes sense. I've just covered it up now. Don't really see the point of it.
        Yes, good point, a bit of black electrical tape should do the trick.
        Annoying they made them the same colour, BSW should be red you’d think.
