Originally posted by Paulyboy
View Post
Disabling the DRL function from the "light-cluster" shouldn't be difficult - but it's a tad problematic for me to be precise because I'm less familiar with the UK MK7 GTI pp (which I believe is 3 x door car). But it shouldn't be too hard if you are prepared to experiment.
I'm guessing from reading THIS that the "light cluster" is what is euphemistically called twin "angel-eyes". If I'm correct, there are 2 x pairs of Leuchte-sets (i.e. 4 x Leuchte-sets in total) that control DRLs in your BCM (the module @ address hex09). These Leuchte-sets are:
- Leuchte4TFL LB4
- Leuchte5 TFL RB32
and
- Leuchte2SL VLB10
- Leuchte3SL VRB21
Again, if I have guessed correctly, on each of the 4 x Leuchte-sets above the Lichtfunktion A channel should be factory programmed to the setting Daytime running lights. Please confirm that this is so on your car.
If the Lichtfunktion A channel has the DRL command, then try changing Leuchte2SL VLB10-Dimmwert AB 2 and Leuchte3SL VRB21-Dimmwert AB 3 from 100 to 0. If these changes are not successful in disabling the DRL function from the angel-eyes, revert these changes back and change Leuchte4TFL LB4-Dimmwert AB 4 and Leuchte5 TFL RB32-Dimmwert AB 5 from 100 to 0.
Don
