hey guys.
i accidentally cracked my LHS mirror LED strip by 1mm while exiting my garage..
it caught on the point where the LED strip points off off the mirror by 1 - 2mm and cracked the plastic off in that corner by about 1 1/2 inch and some plastic clip / attachment inside the housing looks cracked off too.
after inspecting and testing if it still worked ( led strip still works fine) , I taped the corner and sealed where its cracked / exposed and put the mirror cover back over the top into place. will do the job for now hopefully.
i've started to look online for side mirror housing cases or replacement LED strips but cannot find much.
does anyone know of the exact part or know of where to get a replacement LHS side mirror led strip for a golf R Mk7 or a new housing for the mirror.
i've seen 1 LED strip in particular on ebay but not sure if it will fit
OEM Side Mirror Turn Signal Light lens FOR VW Golf7 Golf 7 Mk7 GTI R VII LEFT | eBay
Let me know if you happen to know thanks boys
