Lose ECU In MK7 R
  • Lose ECU In MK7 R
    Hey I was just having the usual engine bay and fluid check the other day and noticed my ECU inside that locked black steel case is lose and wobbles about. It’s the first time I’ve noticed this and just want to make sure either it’s normal or it should be secure. I can grab the wiring look that comes out the front and shake the ECU.
    2015 Golf R. Lapiz Blue.
    I can check mine today by I recall it being rock solid.
    Mk 7 R Wagon Wolfsburg. APR Stage 1. Removable towbar.
      Cheers mate.
        It should be solid - not sure if there’s a bracket though or how it’s affixed
        The battery has a bracket at the bottom front holding it in place
        2006 MkV 2.0TDI -> 2005 MkV GTI -> 2008 MkV R32 -> 2013 Polo 77TSI + 2016 Mk7 Golf R Wagon
          Has the car been chipped? If so, some companies need to remove the ECU in order to tune it and they may not have put it back correctly.
            No not been chipped, my thoughts is though it should be solid.
              It certainly shouldn't be loose - perhaps what ever clips or fasteners they use to secure it have broken or worked their way loose? You will need to have a poke around under the bonnet to see whats going on.
                Checked it. It’s solid as. 5mm lateral movement as the frame flexes on its attachments. 0mm fore and aft.
                  Thanks everyone. I’ll book it in.
