Opened the boot on my Alltrack yesterday to find everything in the back was saturated. Roof lining all stained and water running down the RHS Cargo window. Anyone else had this problem? I have probably used the sunroof 6 times in the last two years so I doubt its wear and tear on the seals. Pain in the arse as I would never option a car with a sun roof it just happened to come with one with the sports pack. Car is parked facing uphill on a sloping drive.
Car full of water - Sun Roof Leaked
Leaking sunroofs seem to be a problem with some VWs, unfortunately. Often turns out to be a problem with the drains. If you are covered by warranty take it to your dealer.2017 MY18 Golf R 7.5 Wolfsburg wagon (boring white) delivered 21 Sep 2017, 2008 Octavia vRS wagon 2.0 TFSI 6M (bright yellow), 2006 T5 Transporter van 2.5 TDI 6M (gone but not forgotten).
I'd be very surprised if it is not a blocked drain, seems to be the most common reason for any sunroof to leak.Originally posted by Why? View PostOpened the boot on my Alltrack yesterday to find everything in the back was saturated. Roof lining all stained and water running down the RHS Cargo window. Anyone else had this problem? I have probably used the sunroof 6 times in the last two years so I doubt its wear and tear on the seals. Pain in the arse as I would never option a car with a sun roof it just happened to come with one with the sports pack. Car is parked facing uphill on a sloping drive.
George06 Jetta 2.0TFSI Killed by a Lexus!
14 EOS 2.0 TSI has arrived!
I had the same issue
I park like you do nose up so all water goes down rear drains
I apparently had a kinked hose on the passengers side leading to a spare wheel well full of water and a shorted out subwoofer
All fixed under warranty took 2 weeks
I will be taking the car to a sunroof specialist every 12 months to get the drains cleaned am now paranoid about leaks as i bought the car intending to keep my car for 10+ years2017 Golf Alltrack 135tdi All options
19 inch Brescia Wheels Golf R brakes front and rear
Calipers painted Candy apple gold
New rear sway bar and linkages
I've had a few VWs with sunroofs, always had trouble !Originally posted by Why? View PostHi Kachingg,
I have had lots of cars with sun roofs never had an issue before. Its good to know about the drains from now on i will get them checked.
I have found parking on a slope in such a way that water runs to just 1 corner will cause a leak in heavy rain.MK4 GTI - Sold
MK5 Jetta Turbo - Sold
That pretty much sums up my driveway. First car i have had trouble with though and first time for this car in 2.5 yearsOriginally posted by JustCruisn View PostI've had a few VWs with sunroofs, always had trouble !
