Missing front grille and parking sensor
  • Missing front grille and parking sensor
    Hi All - excuse the (mostly) repost, I used it in my newbie post, too
    I joined this forum for advice, I seem to have been the victim of a little vandalism - I have had the front left grill insert and parking sensor stolen from my Mk6 Golf R There isn't any damage to the bumper at all... however, the rearview camera and other (still remaining) sensors don't work, im guessing because there is a short in the system.
    All that is left is a hole and three exposed wires (from the sensor)... The smash repairs have quoted me $900+ to fix it (apparently they need to fashion new looms and things)... but I am a little dubious about that. Why would you need to?? its a new(ish) car, surely I could buy a new loom/whatever I need and just plug it/solder it in?
    so im after learned advice - what parts do I need to fix it?? My initial searches on eBay and VW parts haven't given me anything definitive - and im not sure if I need a new loom for the sensor?
    Ontop of this, how hard is it to do?? I can wire and solder and am mechanically minded - I cant quite see how its a $900 fix job, considering the new parts should just slot in (unless the wiring for the new sensor is actually complex??)... and that is... if I knew what the parts were!
    Looking forward to your helpful helpiness!
    Thanks
    New sensor, new connector and the three wiring pins. Put it altogether and fixed. Only other thing you will need is a diagram to see where the wires go, but you may be able to decipher it by looking at the other sensors.
    System shuts down as soon as one sensor has a fault.
    Volks Handy
      That's brilliant, thanks Snail Style,
      Dont suppose you can suggest the parts I need - or am I best going through the VW service desk to get them?
        All good, I just ordered it through the VW parts desk... its a LOT cheaper than the smash repairs... lets hope it all goes together Ok!
        Thanks again for your help!
          When getting small items like that VW is always best. Sensor is around the $50-100 mark and connecters and wires shouldn't have set you back more than $50?
          Volks Handy
            Not quite...
            $197 for the grill
            $196 for the sensor
            $20 for a new plug
            Still, heaps better than getting someone to do it for me... ill spend the next little bit under the car - hopefully itll be a nice snappy job!
              Wow sensor ain't cheap. I threw one away when i moved to Perth 6 months ago because no body wanted it. Had it up for $30...
              Volks Handy
                Probably would have been worth hitting up the wreckers for that price., probably could have just nipped off the cables with some wire cutters and matched the colours
                Good luck with it, let us know how you go getting it all back together.
                  Picked up the pieces yesterday and all looks good...
                  ... except the grill doesn't come with the mounting bracket for the sensor... Errgh!!
                  Have now reordered it - so the pieces needed are
                  grille
                  sensor
                  plug
                  mounting bracket for sensor in grille
                  Now all that's left is to try and figure our what wire goes where - and how to use the plug... im thinking removal of the right side grille may be needed!!
                  (ps. just realised it should be grille, not grill... I was obviously in BBQ mode earlier)
                  Will keep you all posted and try for pics if it would be useful for others down the track. seems like such a stupid act - why steal a bumper insert and sensor that is very specific to make and model??
                    Soooo... further information.
                    After picking up the parts and getting ready to install the new bits, I realised that the sensor bracket needs something to clip into... after a fair amount of googling (and slight pulling apart of the car), it seems there is a plate that sits behind the grille that the sensor bracket plugs into... and a rubber seal that goes around the outside of the sensor itself.
                    only trouble is - the VW dealership doesn't know of any part and the other local place would like me to drive out and discuss it. Ho hum.
                    No I am trawling the interweb looking for part numbers.
                    its never just easy
                      Going to the wreckers then returning all those parts is looking like a better and better option
                      (But I understand the draw of shiny new parts too).
                        Having this chance again - id go to the wrecker without a doubt!!
                        *hopefully* the order I have placed will be the last and I can put it back together now!
                          Almost worth an insurance claim for the cost and amount of screwing around.
                          MK4 GTI - Sold
                          MK5 Jetta Turbo - Sold
                            Youre not wrong, JustCruisin
                            It is getting to the point that it wouldn't have cost much more for insurance to fix it... and they could have worried about the parts!!
                            That being said, part pickup #5 is this afternoon, stay tuned!
                              So - I finally got the parts and put them in and it all works again...
                              sorry - I didn't take pics... for a couple reasons
                              1) by the time I bought all the pieces necessary (grille/sensor/plug/bracket/mount for rear grille/seal/clips) I was probably a touch over $600 in oem bits - meaning excess would have been a pretty smart way of doing it
                              2) As the Hawk said - the much easier job would be to grab on from a wrecker and clip the wires!
                              The process was really easy -
                              1) assemble grille with plate and clips
                              2) feed wires through sensor hole and bracket and clip wires into plug
                              3) clip plug into sensor
                              4) clip sensor to bracket (with seal)
                              5) clip bracket to grille
                              as soon as this was done, all sensors and the camera came back perfectly.
                              Thanks for all your help - hopefully if someone else has the same problem, they will be able to work out the best way of fixing it from this thread (recommend excess or get the assembled bit from the wrecker)... if not, and they want to do it themselves, im happy to try help out
